Question on piston dome volume
Old Jan 30, 2002 | 01:29 AM
MoMo's Avatar
MoMo
Default Question on piston dome volume
Does anyone know how to read the advertised dome on pistons and convert that to cc's?
I have TRW forged 435 horse 427 pistons which are advertised with a 0.255" dome. Every calculator wants cc's. When they advertise a dome, they couldn't mean "0.255 cubic inch dome volume". I can believe it's 0.255 linear inches tall, but that provides no information about dome volume.
It's supposed to work out to 11:1 compression on 109 cc heads, standard Chevy BB deck height, and standard Felpro head gasket, on a 0.030" overbore according to the machinist. But I'd really like to check his math.
Thanks.
Old Jan 30, 2002 | 02:23 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Question on piston dome volume (MoMo)
what part # is stamped on the piston top?
Old Jan 30, 2002 | 11:09 AM
Lt1er's Avatar
Lt1er
I have a speed-Pro forged piston cat. It lists: 427 closed chamber stock type .300 dome/pressed pin Same as L72, L71 435/425 hp and L89 435 hp 11.25 C/R w/106.9 cc chamber
So yours with a little less dome and more than 106.9 cc would be right at 11.
Old Jan 30, 2002 | 03:43 PM
Flareside's Avatar
Flareside
No way you'll figure cc from that .255" height figure. You'll have to find the actual cc info somewhere, or cc them yourself. Unfortunately, the only way I know to cc the dome is to first install them in the engine, then set the piston a measured distance down from the deck, then fill it. Maybe there's another way I've never seen? I'm assuming you don't have the block and pistons handy.
[Modified by Flareside, 2:45 PM 1/30/2002]
Old Jan 31, 2002 | 12:39 AM
gkull's Avatar
gkull
Default Re: Question on piston dome volume (Flareside)
Just like measuring the volume of any irregular shaped object. You place it in water and read off the added graduation lines. So if you could find a big enough cc graduated beaker and only imersed the dome it would tell you the number of cc's
Old Jan 31, 2002 | 02:28 AM
clem zahrobsky
Cruise-In I Veteran
the volume is std bore 36.3cc, +.030= 35.5cc, + .060= 34.2 cc :chevy any thing else?
[Modified by clem zahrobsky, 1:29 AM 1/31/2002]
Old Jan 31, 2002 | 08:45 AM
GregP's Avatar
GregP
Go to (when it's up ) http://www.nhra.com/tech_specs/engin...ts/CHEV-67.rtf It lists the 435/427 as 36.34 cc dome, 0.35 height
-Greg
Old Jan 31, 2002 | 09:37 AM
Flareside's Avatar
Flareside
Default Re: Question on piston dome volume (gkull)
See, I knew there were smarter people around here!
Old Jan 31, 2002 | 01:06 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
You can duplicate the old head CCing technique with a piece of plasticine modeling clay (the oily stuff.)
Make a frame out of wood lath (paint stirring sticks work pretty good, press the clay in the frame and scree it off perfectly flat with a metal straight edge. Wet the top of the piston and press the dome of the piston into the clay(water will keep the piston from sticking) until the top edge of the piston is level with the top of the clay.
Take a 100 m/l graduated cylinder, fill it too the 100 m/l. use a flat piece of lucite plastic with a hole in it. Lay it on top of your imprint of the piston dome in the clay. Pour the water into the hole until it is completely full.
Look at the amount of water in the cylinder, the amount that you poured out is how much volume the dome displaces in CC's. 1 ML = 1CC.
Old Jan 31, 2002 | 03:30 PM
Flareside's Avatar
Flareside
Default Re: Question on piston dome volume (Smokehouse69)
Ok, anybody know a convenient source for a graduated cylinder? Pharmacy? I just got my new SRP pistons today!
-Joe
[Modified by Flareside, 2:31 PM 1/31/2002]
Old Jan 31, 2002 | 07:03 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Question on piston dome volume (clem zahrobsky)
There are several good suggestions for measuring the dome volume, here. The height of the dome in the catalog is merely a discription. If the dome volume isn't listed in the back of the book, under "specs", call the manufacturer. They will tell you.
Old Jan 31, 2002 | 08:21 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Go to any place that sells horse/cow stuff. Now Now.... I meant supplies, not the other!
Feed stores, saddle tach stores etc all have cheap syringes that work great. They are available in many sizes from 25cc to Oh my God size.
Jim
Old Jan 31, 2002 | 10:44 PM
Flareside's Avatar
Flareside
Default Re: Question on piston dome volume (427Hotrod)
Jim
Cows? In Jersey? :lol: :lol: Thanks Jim, I'll look for a horse supply place. :D
[Modified by Flareside, 9:45 PM 1/31/2002]
Old Feb 1, 2002 | 08:17 AM
mountainmotor's Avatar
mountainmotor
Quote:
"Ok, anybody know a convenient source for a graduated cylinder? Pharmacy? I just got my new SRP pistons today!
-Joe"
Will you mail a pic of those shiney new SRP's?
Old Feb 1, 2002 | 10:12 AM
Flareside's Avatar
Flareside
Default Re: Question on piston dome volume (mountainmotor)
-Joe"
Sure will Curtis. You'll have them tonight.
-Joe
Old Feb 1, 2002 | 11:25 AM
gkull's Avatar
gkull
To all of you engine builders put those pistons back in the boxes and send them out to get them thermally coated. Then you won't have to worry about using pump gas and higher compression.
To Question on piston dome volume
