question for those with simulation software???
Old Feb 8, 2002 | 12:07 PM
johndezman's Avatar
johndezman
Default question for those with simulation software???
i am having the following engine installed next week. can anyone tell me what hp and torq this combo will have?
406 ci
trick flow twisted wedge heads and approximately 9.8:1 compression
super ram w 52 mm throttle body
1 5/8 long tube headers, into 2 3/4" borla off road exhaust - no cat
214*.486 lift intake; 218*.488 exhaust 108*ls
7 qt pan with diamond stripper windage tray
any help greatly appreciated
thanks
Old Feb 8, 2002 | 12:08 PM
johndezman's Avatar
johndezman
Default Re: question for those with simulation software??? (johndezman)
forgot to mention the ecm will be the 7165 and an ed wright custom chip.
Old Feb 8, 2002 | 12:44 PM
Monty's Avatar
Monty
Old Feb 8, 2002 | 01:28 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: question for those with simulation software??? (Monty)
Hey Monty...
What settings did you use to get those #'s?
Could you get a screen capture of the left side?
thanks
Old Feb 8, 2002 | 03:42 PM
Monty's Avatar
Monty
Default Re: question for those with simulation software??? (-=Jeff=-)
Old Feb 8, 2002 | 05:56 PM
johndezman's Avatar
johndezman
thanks for the reply i appreciate the input. my "guess" was 370 hp and 450 ft/lbs - these "sound better" more exiting.
thanks again
Old Feb 8, 2002 | 06:09 PM
Monty's Avatar
Monty
John,
I think you could stand to use a larger cam. 214/218 cam is pretty mild for a 406SR motor. I don't know if a roller cam is out of the questions, but it would be a nice upgrade as well. I think you could stand to use a cam with 220 to 230 degrees of duration while still maintaining a good idle/vacuum, and providing tremendous torque, probably around 500 lb ft.
Old Feb 8, 2002 | 06:13 PM
johndezman's Avatar
johndezman
thus far the converter will be left stock and i was concerned about idle and waiting at traffic signals.
also there's some "stealth" in mind so that the old stoplight grand prix goes my way!
i have a 224/240 "on the shelf" if i get a different converter next winter
Old Feb 9, 2002 | 03:03 PM
dtorc4's Avatar
dtorc4
I would highly recommend a roller cam motor. If monty would run the same motor, same dur., w/ a roller cam, you will probably gain a good 20 hp or more.
To question for those with simulation software???
