Quick question about block/head coolant passages.
Old Feb 9, 2002 | 03:13 PM
dtorc4's Avatar
dtorc4
Default Quick question about block/head coolant passages.
http://forums.corvetteforum.com/zerothread?id=235429
Thanks!!! :cheers:
Old Feb 10, 2002 | 12:09 AM
danno85's Avatar
danno85
Default Re: Quick question about block/head coolant passages. (dtorc4)
The large hole(s) in the deck of block provide help for getting the sand
out at the factory after the block is cast, and then small holes are used in
the gasket to block off and/or meter the water flow.
Old Feb 10, 2002 | 03:36 AM
GlockLT4's Avatar
GlockLT4
Default Re: Quick question about block/head coolant passages. (danno85)
Yup.. freeze plugs just plug up the casting holes..
To Quick question about block/head coolant passages.
