Fluidampr
Old Jul 2, 2009 | 06:14 AM
94z07fx3's Avatar
94z07fx3
Default Fluidampr
Anyone using a Fluidampr harmonic damper?
What are your thoughts?
I have a 7.4 liter BBC in a Suburban and its harmonic damper seems to function ok but it has rust, age, and 200,000 miles on it. I was thinking of just putting a stock damper on it but when I was looking for one I ran across the Fluidampr and wondered if it could help the BBC in the smoothness category.
Old Jul 3, 2009 | 10:51 AM
babbah's Avatar
babbah
I have a fluiddampr HB on my 67 BBC. Works flawlessly! No problems. Get one, and no more worries about your balancer. PS- They are not cheap!
Old Jul 3, 2009 | 01:09 PM
BLOCKMAN's Avatar
BLOCKMAN
What's interesting about a fluid dampner you can't balance a crank with one as it will not repeat twice and it does through the rear off as well.
When you balance with a fluid dampner the outter ring has to be taken off.
Old Jul 3, 2009 | 01:58 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Would you like to explain how that's done????????
Old Jul 3, 2009 | 02:57 PM
BLOCKMAN's Avatar
BLOCKMAN
Most fluid dampners are 2 peice design and on the BBC's we have balanced for other shops we have to take the otter ring to balance or it will never repeat on both ends.
Old Jul 5, 2009 | 07:41 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
At 200K in a suburban I'd just get a stock one.
Otherwise I lean towards ATI exclusively. Not too wild about the fluid ones unless its a very limited RPM range....like the diesels they were designed for.
JIM
Old Jul 19, 2009 | 08:11 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Thats hi-milage and the vlv train probly has plenty of slop.
The idea of silicone fluid in a dampner is to reduce timing chain scatter from the crank pulses. But with 200k mi your overdue for a new timing set (and cam if a flat tappet) already. A fairly more expensive Fluidampner would be an unnecessary expense. U would be better off using a inexpensive stock dampner and spend the difference in $$ to buy a new timing set.
On the other hand the Fluidampner's are not expected to wear/rot out like a stock elastomer dampner.
Hope this helps ya',
cardo0
Old Jul 20, 2009 | 06:32 PM
cv67's Avatar
cv67
St. Jude Donor '05
Cheap stocker, the way they can oscillate is a good thing in terms of crank twist, etc.
I dont know this for fact but I have heard of a few cases where, in freezing temps the Fluidampners have failed and caused damage due to the fluid freezing. True, who knows
With that said Ive used them on two different motors, happy with them .
Old Jul 23, 2009 | 12:06 PM
Cstraub69's Avatar
Cstraub69
I know of at least 3 crankshaft manufacturers that don't recommend fluid dampers. This technology comes from low rpm diesel applications where the dampers were matched to the rpm the engine would be running for most of its life. These engines recieved the same crankshaft and other components in which the damper was tuned for. A Bryant billet compared to an Eagle 4340 crank with the same stroke will not have the same harmonics.
To Fluidampr
