small block head question
Old Feb 17, 2002 | 10:13 PM
BC66's Avatar
BC66
Default dumb small block head question
Hi I'm about to put my redone original 66 327 heads back on my motor .
Well they look identical except for an E246 casting# on one and an E 256# on the other . I think the E 256 was on the right side ,but I'm not sure ,or are they interchangable from left to right ? Also any recomendations for sealant for the headbolt threads going into the water jackets ?
Thanks Bruce :confused:
[Modified by BC66, 8:17 AM 2/18/2002]
Old Feb 18, 2002 | 04:05 AM
Jvette73's Avatar
Jvette73
Default Re: small block head question (BC66)
The heads are interchangeable from side to side. Before deciding which head to put on which side, check the accessory mounting holes on the end of each head. If you find any damaged threads, you can put that head on the side that would put the damaged threads facing rear. Use permatex #2 or equivilant to seal headbolt threads. This is the black, pliable, non- hardening sealer. Also good to use it on the intake bolts. Or so says the Haynes manual.
Old Feb 18, 2002 | 11:27 AM
BC66's Avatar
BC66
Default Re: small block head question (Jvette73)
Thanks John
I'm just about to button it up and don't want to make any mistakes.
Bruce
To small block head question
