Can some one refresh my memory
Old Mar 3, 2002 | 01:17 AM
88-406's Avatar
88-406
St. Jude Donor '05
Default Can some one refresh my memory
Hydraulic roller cam's need a distributor gear made out of what?
KM
Old Mar 3, 2002 | 04:00 AM
JAKE's Avatar
JAKE
Default Re: Can some one refresh my memory (88-406)
Depends on who made the cam.
Most of Crane's that are street hydraulic rollers have a "IG" at the end of the cam number, which stands for Iron Gear.
If the cam is a steel billet, you need an aluminum/bronze gear.
GM roller cam crate motors and all their roller cams call for a melonized distributor gear which you get from the Chevy House. I have the part # tucked away somewhere if you need it.
To be sure, you should call the cam manufacturer.
I read a Tech article recently where this question was sent in and the Tech writer called MSD and they said when in doubt, use a aluminum/bronze gear.
Gets confusing doesn't it.
Be sure to let me know what you come up with. My roller's eating my distributors right now! TPIS told me to use a stock gear on their ZZ9, but the stock gear's gettin eaten alive.
Jake
[Modified by JAKE, 2:02 AM 3/3/2002]
Old Mar 3, 2002 | 09:36 PM
88-406's Avatar
88-406
St. Jude Donor '05
Default Re: Can some one refresh my memory (JAKE)
Thanks for the advice Jake.
KM
To Can some one refresh my memory
