Aluminum Big Blocks?
Old Mar 6, 2002 | 09:21 AM
groovyjay's Avatar
groovyjay
Default Re: Aluminum Big Blocks? (Sigforty)
Sigforty: Thanks for the info! :cool: :eek: :cheers:
Old Mar 6, 2002 | 09:23 AM
groovyjay's Avatar
groovyjay
Default Re: Aluminum Big Blocks? (Monty)
QUOTE:"aluminum blocks offer a weight savings and repairability advantage."
Sounds like reason good enough for me!
Old Mar 6, 2002 | 06:06 PM
VETMANIAC's Avatar
VETMANIAC
Default Re: Aluminum Big Blocks? (555ciC4)
555ciC4,
That sounds like a killer engine you have there. What are the specs on your camshaft? What heads are you running and please give us the details on your Fuel Injection system. Thanks.
Old Mar 6, 2002 | 08:11 PM
555ciC4's Avatar
555ciC4
Default Re: Aluminum Big Blocks? (VETMANIAC)
Cam specs: hydraulic roller, 256/262 @ 50, .657/657 lift and 114 degree lobe separation . Brodix/SAR BB-2X CNC heads. http://www.sonnysracing.com/engines_may_2001.html has more details,
SAR STREET/STRIP
555 CHEVY - 1X4 700 HP
DESIGNED TO RUN ON 93 OCTANE PUMP GAS,
9.5 TO COMPRESSION
CROSS COUNTRY ENDURANCE
See http://www.fuelairspark.com/ for EFI info. Mine is sequential with individual Cylinder Fuel and Spark Control.
[Modified by 555ciC4, 12:42 AM 3/7/2002]
Old Mar 7, 2002 | 12:14 PM
VETMANIAC's Avatar
VETMANIAC
How does the engine idle with that camshaft? What RPM does it idle at and how much vacuum is it pulling at idle? Is that a Crane Camshaft? I noticed that the specs @ .50 are similar to a Crane profile but the lift is greater. Are you running greater than 1.7 to 1 rockers? I am curious what spring pressures you have closed and open and how well the Hydraulic lifters are holding up to that much lift. Which lifters are you running? Also, can you run the F.I. in closed loop or must it remain in open loop? I know this is a lot of questions but I would appreciate the info since I plan on a future cam change and switch to F.I. for my 540. Thanks for all of the info.
Old Mar 7, 2002 | 12:43 PM
555ciC4's Avatar
555ciC4
It idles between 650 and 850 rpms with 8-10 inches of vacuum. My power brakes still work as stock. Custom grind, I think that told me it was Comp Cams. Yes, 1.7 rockers. Not sure of spring pressure or lifters. I run closed loop and speed density.
Old Mar 16, 2002 | 04:14 PM
MassVette's Avatar
MassVette
Man, what a crazy car! I LOVE it!!!!!!
:yesnod: :chevy :chevy :yesnod:
Old Mar 16, 2002 | 10:19 PM
555ciC4's Avatar
555ciC4
Default Re: Aluminum Big Blocks? (MassVette)
Thanks. :D
Old Mar 16, 2002 | 11:17 PM
korvetkeith's Avatar
korvetkeith
Well it begs the question, whats she run?
