HELP! What do I check first?
Old Feb 6, 2010 | 05:25 PM
litevette's Avatar
litevette
Default HELP! What do I check first?
I took my '68 Firebird out for a spin today. Cranked up fine. Idled fine in the warm up, tapped the accelerator to lower the rpm's, backed out and off I went. When I got down the road, just a few miles, it wanted to die on me at the stop lights. As long as I shifted into neutral and kept my foot on the gas some, it would keep running. If I took my foot off the gas it would die. Where would you start looking for a problem? Fuel pump? Carb issue? Thanks in advance for your help!
Old Feb 6, 2010 | 07:33 PM
litevette's Avatar
litevette
30 views and no replies yet. Anyone? Anyone?
Old Feb 10, 2010 | 05:03 PM
BogusSVO's Avatar
BogusSVO
how long has it been sitting?
what carb? maybe just the curb side idle stop screw moved some ?
have you done a vac reading?
Old Jul 2, 2010 | 05:09 AM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Check the fuel filter.
Old Jul 2, 2010 | 10:54 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Sounds like it's lean at idle or timing is way off. Start with timing and then check carb. Not knowing the combo it could be:
Timing too low
Vacuum leak
Idle mixture set wrong
Cam requires more airflow and it's idling too low
Idle feed restrictions/air bleeds need to be tweaked (not as likely)
Give us more details. Carb, cam, cubes, converter, idle stop solenoid, A/C?
JIM
To HELP! What do I check first?
