350 sbc build
Old May 7, 2010 | 06:48 AM
hdbob's Avatar
hdbob
Default 350 sbc build
Im trying to build this engine for a 67 camaro I just picked up... car came in pieces.. Motor has potential. the block has 030 over flat pistons, and was told it had a SERIOUS cam... and they screwed up the stock heads when they ran it.
well I got a set of rebuild 202 heads with 550 lift springs, holley 750 carb and a performer rpm manifold, roller rockers??? yes ??NO, or roller tip????
Im thinking of pulling the cam and geting a Comp thumper cam or the ***** thumper.. the car has a powerglide tranny.. I just want a good sounding motor with some lope and good HP.... Nothing too radical... If I need a stall converter , thats fine..
How does this set up work?? expected HP range?? which cam thumper or *****??
Another option was to put this motor in the vette and I have access to a 327 complete stock and put that in the 67, but leaning towards leaving the vette alone.
thanks guys.. appreciate any imput..
Old May 7, 2010 | 10:53 AM
mr.beachcomber's Avatar
mr.beachcomber
A little background info would help:
Is the engine block a two-bolt main 327 or a four-bolt 350? (I know you said 350 in the title, but did you check the crankshaft?)
What size wheel/tire will you be using?
What is the rearend ratio? Is it posi or open diff?
Is the Powerglide a stock unit or a racing unit?
Last edited by mr.beachcomber; May 7, 2010 at 10:55 AM. Reason: clarifying reason for asking if engine was 327 or 350
