How much can you mill 1999 ls1 heads?
Going to run a 228 cam and want around 11 to 1 static compression
mill the heads 20 thousands and use new gm stock head gaskets? Or ???????
Former Vendor
You need to be down around 59cc on those heads to get to 11:1 on a stock bottom end LS1. The stock heads are on 66cc. At about .006-.007" per cc, you need to mill about .040" off those heads.
Jon
Jon
Texas Speed Rocks!
left you a response on the other thread
http://forums.corvetteforum.com/engi...post1576272190
