[Suggestion]: What Head Gaskets
Old Apr 11, 2002 | 04:45 PM
scorp508's Avatar
scorp508
Default [Suggestion]: What Head Gaskets
Just looking for a quick recommendation on head gaskets.
I currently have a pair of Felpro 1094s that I was going to use, but FelPro supposedly says that they will not hold up to over 10.5:1 compression which is right about there these would put me.
The engine is your standard '87 Aluminum Head 9.5:1 L98 with a set of D-Port Aluminum L98 heads going onto it. The block is clean and has not been touched since it left the factory.
So, I need a nice reliable head gasket for use with the Aluminum heads.
Suggestions? :)
[Modified by scorp508, 5:01 PM 4/11/2002]
Old Apr 11, 2002 | 05:02 PM
countryvette's Avatar
countryvette
Default Re: [Suggestion]: What Head Gaskets (scorp508)
I just put a set of these Aluminum heads that had been worked on my 79 and the gasket recommended for my application by various members of the forum for my 10.8:1 compression flat top piston motor was the Felpro 1010. So far no problems.
Good Luck
David
Old Apr 11, 2002 | 05:04 PM
WINNER's Avatar
WINNER
Cruise-In II Veteran
1049 or 1094? I'm using Felpro 1010's on mine :cheers:
Old Apr 11, 2002 | 06:00 PM
scorp508's Avatar
scorp508
1094, I'm sorry I reversed it.
Old Apr 11, 2002 | 07:22 PM
65Z01's Avatar
65Z01
Scopr, what minimum deck height are you shooting for? I've read that .040" is min and again that .029" is min. It depends on piston material & configuration as well as valve train setup.
Anyway, that's the real concern in gasket choice, enough clearance when hot to clear the valves as well as the head.
Minimize quench/swirl while doing no damage to maximize CR and reduce octane sensitivity.
Old Apr 11, 2002 | 10:12 PM
scorp508's Avatar
scorp508
Jim I honestly don't have a target, nor would I know WHAT to shoot for. :)
Old Apr 12, 2002 | 12:33 PM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Default Re: (scorp508)
Scorp, I used a set of victor reinz gaskets I got from LPE. They are .029 compressed thickness. This is what they use all the time on their stuff, I figure they know what theyre doin. You can order them over the phone.
As for quench height I had my heads cut .010 and used the above gaskets rather than the thicker .39 compressed thickness stock gasket. It may have been good for a small bump in cr and hp. Another benefit of reducing quench is you can run more timing. There was a great thread on quench area in the engine mods section about a month or two ago. See if you can find it. Lots of great info in it.
[Modified by red90sixspeed, 10:36 AM 4/12/2002]
Old Apr 12, 2002 | 03:07 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: (red90sixspeed)
I am around 10.5:1 compression and I am using Felpro 1010 gaskets
Old Apr 12, 2002 | 04:55 PM
65Z01's Avatar
65Z01
Scorp, browse this link on "quench": http://forums.corvetteforum.com/zerothread?id=255840
Old Apr 13, 2002 | 03:31 PM
Redmenace's Avatar
Redmenace
I've had good luck with the 1010's on both my vette with Edelbrock heads and my blown Jeep with AFR heads.
Old Apr 13, 2002 | 11:51 PM
65Z01's Avatar
65Z01
Scrop, since you're not doing pistons or block, maybe you could use the TPIS standard 350 head gasket #700-306 @$39/pair. It has a thickness of .029" and raises compression by 1/2 pt and reduces quench area for a 10hp gain.
Old Apr 15, 2002 | 03:00 PM
ralph's Avatar
ralph
Default Re: [Suggestion]: What Head Gaskets (65Z01)
this is the best i could come up with for my rig:
Victor 5746....026 compressed; good to 14:1, no overlap into cylinders; good for Alum heads.
Old Apr 18, 2002 | 05:56 PM
Matt Gruber's Avatar
Matt Gruber
scorp
i block sanded the heads on my 72, to use with .015 shim hg,
they need a smooth surface, if you spend 1/2 hour each block sanding with 400, you will have a much better chance of success.
on my 61 i used the 1010, that was before i understood the above.
Old Apr 18, 2002 | 09:58 PM
scorp508's Avatar
scorp508
I ended up with a set of 1010s, got here today. Thanks guys. :)
Old Apr 19, 2002 | 03:23 AM
rainman69's Avatar
rainman69
Default Re: (65Z01)
Hey that's my topic on quench! :cheers:
An update:
11.2:1 compression ratio (possibly higher, since they are 64cc heads, decked .010) with 91 octane gas...drumroll please...
No detectable detonation...gaskets seem to be sealing just fine. I wound up with a .015 Fel-Pro and .028 deck height...giving a .043 quench height. Don't remember the Fel-Pro numbers though...but they are steel shim rubber coated, and I smeared them with Blue goop (very thin layer) before installing. No problems at 450 miles...
Oh, and I didn't smooth my block/heads...they were already pretty nice.
[Modified by rainman69, 12:25 AM 4/19/2002]
To [Suggestion]: What Head Gaskets
