Gains on porting heads
Old May 11, 2002 | 10:39 PM
Prufrock17's Avatar
Prufrock17
Default Gains on porting heads
Anyone know typically how much horsepower one gains through porting their heads. Specifically maybe a set of Edelbrock Aluminum 64cc heads? Thanks.
Old May 12, 2002 | 12:27 AM
vader86's Avatar
vader86
Default Re: Gains on porting heads (Prufrock17)
depends on what engine its going on
Old May 12, 2002 | 01:07 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
No enough info :(
Old May 12, 2002 | 01:17 PM
SWCDuke's Avatar
SWCDuke
Default Re: Gains on porting heads (mackeyred96)
I depends on the head and how the engine is setup. A modern head with a mild cam will be pretty good out of the box and porting gains may be minimal and not worth the cost.
A vintage head with a street high performance cam will usually yield a 5-10 percent improvement in top end power, with measureable gains starting at the 3-4000 range.
Full porting isn't worth much on the street and can hurt the bottom end, but "pocket porting" - cleaning up the area just upstream of the valve and matching the head ports to the manifold is worthwhile and has zero cost because it's easy to do yourself.
Duke
[Modified by SWCDuke, 9:21 AM 5/12/2002]
To Gains on porting heads
