Vacuum hookups for 6-71 blower applications.
Finally put all the finishing touches on top end of the blower in regards to making all my bracketry, spacer, plates for regulators, etc. In the process of that I pulled the intake and am currently trying to figure out what possible vacuum ports I am going to have to tap into to make everything work. Here basically are my 3 questions.
1. Power Brake Booster - I'm using the basic vacuum assist setup. The vacuum for this Holley recommended getting from the carb adapter plate (one of the two ports in the back of the adapter plate).
2. Signal for Power Valves - I'm using Holley's blower carbs that are set up for external power valve reference. I'm assuming :eek: that I should be referencing vacuum off the intake itself and will have to tap into it somewhere (will probably drill/tap hole into the flat area in front of the distributor). Opinion?
3. Transmission - I'm using a modified Turbo 350, after a few discussions the intermediate sprag is the weak link on these. Transmission has been rebuilt with a aftermarket sprag assembly along with some other goodies that should be more then enough to handle the motor. I have a choice of going with full manual valve body or sticking with the just put it in drive and let it go. BDS has a pressure diversion valve http://www.blowerdriveservice.com/carb_valve.html so the transmission receives the proper signal and shifts correctly. Talking with them (although when I said I didn't have their brand intake they kinda cringed) this also has to be ported to the intake. Has anyone ever dealt with anything like this?
Thanks in advance,
Keith
[Modified by 70PurpleLS7, 10:21 AM 5/21/2002]
BDS had mentioned about tapping into my blow off plate, what type of system are you using. Weiand's blow off plate doesn't allow much room to do any tapping. Have any pictures?
If push comes to shove, I'll tap into the intake in the area in front of the distributor.
[Modified by clem zahrobsky, 2:34 PM 5/21/2002]
Would love to hear more about your boat engine work. e-mail me if you like (greg.page@nrl.navy.mil).
-Greg
[Modified by clem zahrobsky, 11:59 PM 5/22/2002]
Yes, the problem with "adding" blowers to my motors is the compression. They have all the heavy duty internals and forged parts, but the "wrong" ones ... they currently are at 9.8:1 compression.
Chief said I could run 3 lbs boost and get about 550HP. That's only about a 50-75HP boost, which in a (big and heavy) boat isn't enough speed difference to really make it worth while. I've thought about swaping to some better heads, but again 50-75 HP isn't enough to be really significant (maybe 5 mph).
It's much too expensive to have the engines pulled and reinstalled (about $4k last time around, but I did have them do a little hull work too which was probably a grand of it) unless I could get some major increases ... your 750 HP would be nice but probably too much for my drives, which means more money which ... :crazy:
Guess that's why I've left it as it is so far :)
Thanks - Greg
