400 small block
Old May 23, 2002 | 11:05 PM
Mighty Mouse's Avatar
Mighty Mouse
Default 400 small block
I'm starting a build on a 400 small block and would like some input on cams, heads, pistons, cranks or whatever anyone has advice on or experience with. I would like a setup for street in the 400-450 hp range with matching torque. Also would like carb size info. Thanks, :p:
Old May 24, 2002 | 02:28 PM
The Dude's Avatar
The Dude
Default Re: 400 small block (Mighty Mouse)
Cam = A hydraulic roller in the 235-240 duration @ .050" range.
Heads = Dart Pro 1 (200/210/215 c.c.)
Pistons = Forged flat-tops like SRP 138100.
Rods/Crank = Eagle.
Carb = Q-Jet/750-800 Holley.
That'll be $250.
Old May 24, 2002 | 07:03 PM
95vettski's Avatar
95vettski
Default Re: 400 small block (The Dude)
Does the car have a manual or auto tranny?
I would look for a cam with short duration and high lift with fast ramps. A 400ci can tolerate more cam than a a 350ci, but as suggested somewhere around 230-235 @ .050 will work nicely.
No need for a forged crank, a good Scat 9000 or Eagle will suffice for your goals.
:cheers:
Old May 28, 2002 | 11:51 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Re: 400 small block (95vettski)
Here's a thread that going on right now in the C3 section, my be worth checking out before you get too deep into your buildup.
http://forums.corvetteforum.com/zerothread?id=308755
Old May 28, 2002 | 05:22 PM
88-406's Avatar
88-406
St. Jude Donor '05
Mighty Mouse
I ran a 406 in my 88 last year. My combo used Canfield 195cc heads with additional porting. I used the CompCam XE268 flat hydraulic 224/230 @ .050 with 1.6 RR's. My compression was 10.1
That engine made a Hell of a lot torque! I bet it had to be around 500# or more. The little cam idled great and the engine never stalled on me. But If I had to do it over again I'd go with a bigger cam and way bigger heads. The motor was done pulling by 5200RPM or so. The power band was ideal since I was using OEM 5.7's, crank etc.. parts in the bottom end.
I never really tried to max it out in the 1/4 because I couldn't stop the dam thing from leaking oil. But the few times I did run it, it would pull Z06's in the first 60' and they'd never catch up.
I ran a 12.50 witthout dumping the clutch and granny shifting 3-4th. I felt that the engine was not breathing adequately through the M.A.F. and would have done way better with a DFI.
I also did some track testing of various parts! email me if you'd like more info.
KM
Old May 28, 2002 | 09:32 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: 400 small block (88-406)
thats funny i have a maf car and it has gone 11:49 et with a few more tenths left in there also :cool:
Old May 29, 2002 | 12:31 AM
88-406's Avatar
88-406
St. Jude Donor '05
Default Re: 400 small block (CORKVETTE1)
Corvette1
Your car is impressive! No doubt about it... I don't know what the hell was wrong with my 406, but it just wouldn't run the MPH for me. It seemed like everytime I did a induction Mod, it dropped ET and gained very little speed.
Perhaps if it wasn't leaking all the time I would've kept tunning on it. The last time I ran it, it spit out the complete seal behind the dampner. How and why it did that, I will never know. That seal had been replaced 3 times with two different covers. My paitence had reached the end. LeakZilla was retired and eventually sold.
Who did your chip? I wonder if mine was just to conservative?
KM
Old May 29, 2002 | 01:18 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
i was running a stock chip for a while then i went to formato i do not think i gained much performance other than better idle and more mpg :)
Old May 29, 2002 | 01:19 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
sorry to hear about your 406 they really are pretty good motors :yesnod:
Old May 29, 2002 | 01:53 AM
88-406's Avatar
88-406
St. Jude Donor '05
I totally agree they are good Motors. The torque was insane!
KM
Old May 29, 2002 | 05:57 PM
Mojo's Avatar
Mojo
I'm running a 408. While I love the torque, it runs too hot! I can't drive it in town during our 100+ degree summers.
To 400 small block
