85 won't start
Old Oct 6, 2012 | 08:31 PM
1985gold4+3's Avatar
1985gold4+3
3rd Gear
Default 85 won't start
Checked injectors with test light and when plugged last one in I started car and got check engine light. Wouldn't turn over, tried again ang got nothing. No power in cab at all. Previously it was running rough but running.
Old Oct 17, 2012 | 11:50 PM
John A. Marker's Avatar
John A. Marker
Check battery cables. Remove and clean inside of cable clamp and battery surface.
Next check grounds...they are bolted to the block lower rear driver's side of the block.
Are you getting spark?
Check all fuses.
Pull error codes.
Old Oct 19, 2012 | 11:58 AM
1985gold4+3
3rd Gear
Check all fuses.
Pull error codes.
You are the man!! It was the negative cable from the battery. Thanks for your response
To 85 won't start
