Tech Tip--FWIW
Old Jun 5, 2002 | 02:07 PM
The Dude's Avatar
The Dude
Default Tech Tip--FWIW
I discovered this last night because I had to pull the one-piece front timing cover on the current engine in my '76 and I really dislike loosening, dropping or removing the oil pan when the engine's in the car.
Well, the setup that uses the "thick" front seal between the timing cover and the oil pan doesn't require loosening, dropping or removing the oil pan to R&R the timing cover.
Your mileage may vary but this is a cool little trick that made me a happy camper.
