dropped lifter
Old Dec 27, 2012 | 07:52 PM
NotStock's Avatar
NotStock
Default dropped lifter
Doing a cam swap on a ls2. Inserted 1/4 dowels to hold the lifters up. However while I was removing the old cam I heard what I believe was a lifter falling past the dowel. Sure enough, somehow the number 4 cylinder lifter fell into the block. I'm in panic mode now. Any ideas?
Old Jan 4, 2013 | 08:15 PM
Jaycajun's Avatar
Jaycajun
Drop the oil pan and get it out. Make sure that it is the only item that dropped or you will have do go through the entire process again.
Old Jan 4, 2013 | 10:24 PM
NotStock's Avatar
NotStock
Default What a PIA
Jay...you crack me up. Yes, had to drop the front suspension and then the oil pan to get to the fallen lifter. You know the rest of the story. FYI, for anyone else doing this project, a 1/4" dowel is just not thick enough to securely hold the lifters up. Recommend at least a 5/16" dowel or use pen magnets.
To dropped lifter
