Lt-4 heads on lt-1
Old Jan 9, 2013 | 01:50 PM
bk2t50s's Avatar
bk2t50s
5th Gear
Default Lt-4 heads on lt-1
Greetings, I plan to install a pair of factory LT-4 heads, 1.6 rockers, and manifold on my 1994 LT-1 with the 4L60E transmission. I would like to know how much more torque and HP I will get without going to the Hot cam? Also, if I go with the hot cam any idea what rpm stall convertor I will need and how much HP this will generate. The car is not raced and is on the street most of the time. I appreciate any and all advice, thank you.
Old Jan 19, 2013 | 03:36 AM
cv67's Avatar
cv67
St. Jude Donor '05
The LT4 was rated at 30hp more than your Lt1
Dont expect a lot from the head swap. An improvement though no doubt
Old Jan 30, 2013 | 07:26 PM
blkdevl's Avatar
blkdevl
I had lt4 top end with huge cam headers and bigger tb on my 95 I used to have. it put down 350 to tires. Manual trans.
Old Jan 31, 2013 | 02:59 AM
OKZ06's Avatar
OKZ06
St. Jude Donor '13-'14
I have always been told there is alot better use of your monies then swapping to a lt4 top end, unless you have a cheap in on the heads and intake.
To Lt-4 heads on lt-1
