Valve Stem Seals on BB
Old Jul 3, 2002 | 09:23 PM
l78vetteman's Avatar
l78vetteman
Default Valve Stem Seals on BB
I have a set of stock heads for my 65 396 with later model dual springs. Any suggestions for the best valve stem seals to use. The tops of the guides are not machined for aftermarket seals.
Thanks,
Old Jul 6, 2002 | 06:17 PM
bence13_33's Avatar
bence13_33
Default Re: Valve Stem Seals on BB (l78vetteman)
I went through the same problem with my heads. My heads are from 1966 and I have the Comp Cams double valve springs. I had trouble finding valve seals that would work. I ended up taking them to the machine shop to have the valve guides machined for teflon valve seals. They charged me $0.75 per guide for machining.
