Holley question...Smaller carb or jets???
Old Jul 12, 2002 | 11:17 PM
DngrZne's Avatar
DngrZne
Default Holley question...Smaller carb or jets???
I dynoed my car last week at ECS and found that the car is running way too rich, possibly in the range of and 8:1 mix when I get on it. The car is currently running a 402 with an Stealth intake and an 850 Holley double pumper. I was wondering if I can get away with just using smaller jets or should I just go to a 750 or possibly any smaller? Any input would be appreciated. I have about 50 or so HP that I need to stop from going out the tail in black smoke :yesnod:
Thanks,
Chris
Old Jul 12, 2002 | 11:24 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Default Re: Holley question...Smaller carb or jets??? (DngrZne)
You should be able to jet it down, It's probably a little big for what you are doing but it still shouldn't run too rich. Something is out of whack. Are you sure the air filter isn't restricting it (too short?), fuel needles leaking? etc?
A 750 will probably be about right for you.
JIm
Old Jul 12, 2002 | 11:30 PM
DngrZne's Avatar
DngrZne
Default Re: Holley question...Smaller carb or jets??? (427Hotrod)
JIm
I don't think the air filter is the problem as I have a K&N Xtreme 14" filter in the car which should flow plenty more air than the engine is using. I don't think the carb has any other problems in it, just runs REALLY rich once it starts to hit higher RPMs when you really get on the throttle.
Old Jul 13, 2002 | 12:20 AM
Taijutsu's Avatar
Taijutsu
I saw a similar post where the exhaust was opened up and that cured the rich problem and added big hp! Could this be your problem?
Old Jul 13, 2002 | 01:00 AM
DngrZne's Avatar
DngrZne
Default Re: Holley question...Smaller carb or jets??? (Taijutsu)
I don't think so. I'm running long tube Hookers through 3 chamber flowmasters, that's it.
Old Jul 13, 2002 | 02:35 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
what is the LIST # including the - # on your carb air horn? also make sure the carb bowl vents are at least 1/2" below the air filter top cover. :chevy
Old Jul 13, 2002 | 12:14 PM
DngrZne's Avatar
DngrZne
Default Re: Holley question...Smaller carb or jets??? (clem zahrobsky)
I'll have to look. I bought the car with the carb already on it, so I'm not sure about the numbers. I didn't see any readily visible. Where on it would they be?
Old Jul 13, 2002 | 05:27 PM
clem zahrobsky
Cruise-In I Veteran
the numbers are stamped on the front of the choke housing,the part that holds the choke plate. look above the front float bowl. :chevy
Old Jul 13, 2002 | 06:09 PM
Dryseals's Avatar
Dryseals
Pull the back bowl off and see if it has had the power valve plug removed and a power valve installed. Most carbs come jetted a tad on the rich side. If the only time you go rich is with your foot in it then the front jets are OK. Check the jet sizes front and rear anyway so you'll know what you have and check the power valve sizes. Over size jet in the rear and/or the addition of a rear power valve is what I would look for.
Old Jul 13, 2002 | 07:57 PM
DngrZne's Avatar
DngrZne
Default Re: Holley question...Smaller carb or jets??? (Dryseals)
Ok, well I just pulled off both float bowls and this is what I found. The carburator is number 4781-1. Number 80H jets all around. If the power valve is a spring with a diaphram then it has them on the primaries and secondaries and they are both number 6.5. The carb bowl vents have plenty of clearance, and the air filter has an open top so there would be no restriction anyway.
Is that enough info?
Thanks again,
Chris
[Modified by DngrZne, 6:29 PM 7/13/2002]
Old Jul 13, 2002 | 08:33 PM
clem zahrobsky
Cruise-In I Veteran
80 is correct DP are very rich because they are race carbs to be used with open exhausts. i would go to 78 in the pri and 78 in the sec. also take some 76s to the next dyno test. installing some .015 diameter wires in the idle feed restrictions in the metering bodies will lean out the idle and leanout the over all fuel curve.
[Modified by clem zahrobsky, 7:36 PM 7/13/2002]
[Modified by clem zahrobsky, 7:37 PM 7/13/2002]
Old Jul 13, 2002 | 08:43 PM
DngrZne's Avatar
DngrZne
Could you explain that a little more? I'm not really sure what you mean. So you think that the 850 will be no problem then with the right jets?
Thanks,
Chris
Old Jul 13, 2002 | 08:53 PM
clem zahrobsky
Cruise-In I Veteran
a 750 would be better street carb but a 850 would make the most top end HP when dialed in. if you are going to drag race with open headers i would stay with the 850. the idle feed restrictions are the little brass inserts in the metering bodies. chevy high performance magazine a month or two ago had a good article on this. like i said a 750 would be a better all around carb for every day driving. :chevy
Old Jul 14, 2002 | 12:29 PM
QuickVet's Avatar
QuickVet
i think those jets are way to big. in the primaries anyway. jet it down!
Old Jul 14, 2002 | 12:48 PM
L79vette's Avatar
L79vette
Default Re: Holley question...Smaller carb or jets??? (QuickVet)
Double pumpers need bigger jets than single pumpers because they are set up with much less power valve flow. The difference between cruise mixture and power enrichment mixture is very small. They are intended to run at best-power A/F ratio at all times. If you try to size the mains down for a leaner cruise mixture, it will have poor part throttle (hill climbing) power because the power valves flow too little and it will be too lean.
You really want to keep the jetting the same all the way around and just jet for best power. If you have an interest in gas mileage, step away from the double pumper. They just don't work that way. You can mess with the power valve restrictions, but I'd just get a 750 vacuum secondary if you care about mileage.
Old Jul 14, 2002 | 01:29 PM
Dryseals's Avatar
Dryseals
If the rich condition only exists when you have your foot in it then the best thing to do would be to take a manifold vacuum reading at the rich condition. The power valve (that diaphram thingy) is set up to open at 6.5" of vacuum. Most of these carbs are a tad on the rich side and with the power valve opening up can put you a little too rich. This is a big carb for the engine but can be made to work. The key here is to figure out if the A/F mixture is correct for you application. If the manifold vacuum reading is not below 6" when you go rich then look at smaller jets. If the reading is below 6" when the rich condition hits then the power valves are opening and adding more fuel.
To Holley question...Smaller carb or jets???
