Mucie ID help,please..
Old Aug 5, 2002 | 03:45 PM
BB wowbagger's Avatar
BB wowbagger
Default Mucie ID help,please..
Hi..I wonder if theres a Muncie expert among us that could help me with this.I`m about to buy a tranny,but the guy doesent n´know what kind of tranny it is.
The Nr are:
3925661 13N187868 P3H 14B
Rear case Nr:
3915020
I`ve tried 5speed,com but i couldnt get enogh info from there,yet
:cheers: :cheers:
Old Aug 5, 2002 | 07:25 PM
redvetracr's Avatar
redvetracr
Default Re: Mucie ID help,please.. (BB wowbagger)
BB,
Generally (BUT not always) you can go by the rings around the input shaft. No rings usually means it`s an old wide ratio or a M-22 depending on which case and what size pin it takes, two rings it`s a wide ratio and one ring it`s a M-21. REMEMBER I said usually!! To be sure you need to open it up and count the gear teeth (You should always open them up anyway to check the condition) ...redvetracr
Old Aug 7, 2002 | 02:17 PM
ED DINAPOLI's Avatar
ED DINAPOLI
BB,
I am no Muncie expert, but I will give your numbers a try.
Main casting number 3925661 was used from 1970-74.
P3h14B- Is a muncie built in 73{h=june 14=14} B=M21
Hope this helps
Ed
Old Aug 7, 2002 | 09:05 PM
mountainmotor's Avatar
mountainmotor
Have you seen this?
http://www.4speeds.com/muncie2.htm
Old Aug 8, 2002 | 07:46 AM
ED DINAPOLI
Default Re: Mucie ID help,please.. (mountainmotor)
Mountainmotor,
Great summry of muncie info.
Ed
To Mucie ID help,please..
