How much compression ?
Old Aug 7, 2002 | 09:18 AM
GregP's Avatar
GregP
Default How much compression ?
Getting about ready to buy the heads for No Flight. I'm planning to go with spread-port exhaust so will need the heads to fab the headers. Of course, that means I need to decide which chamber volume to get, which depends on how much compression I can get away with. I pplan to use Aluminum heads, and a 240@.050 duration solid roller cam. Can I go as high as 11:1, or do I need to stay in the mid 10's?
Thanks - Greg
Old Aug 8, 2002 | 01:35 PM
Corey_68's Avatar
Corey_68
Default Re: How much compression ? (GregP)
11:1 would be no sweat w/ aluminum heads.
Old Aug 8, 2002 | 04:42 PM
GregP's Avatar
GregP
Default Re: How much compression ? (Corey 68)
I know 10.8 works fin on my BBC's, wasn't sure how high I can go on SBC. I'll probably be right around 10.7 or so, which seems like it should be ok.
Thanks - Greg
To How much compression ?
