exhaust
Old Mar 6, 2015 | 04:33 PM
71frameoff's Avatar
71frameoff
Default exhaust
just built a 427 dart small block. AFR 210 heads 1 3/4 headers, 700R auto trans, 373 rear gears. so what size exhaust pipes should I run?
Old Mar 7, 2015 | 12:12 PM
mr.beachcomber's Avatar
mr.beachcomber
Without knowing much more about your engine's timing events, the best I can recommend is maintain the same size pipe that fits over the collector's reducer all the way back to your mufflers. If you have a choice of reducers, pick one that has at least a 2 1/2" diameter outlet. Having a set of mufflers that will handle the exhaust airflow w/o causing excessive back pressure is a must for best power.
For some very good general header info that might help, check out this article by David Vizard from Stock Car Racing. Here's the follow-up article featuring Jere Stahl on headers.
Good Luck!
Last edited by mr.beachcomber; Mar 9, 2015 at 08:22 AM. Reason: Added outlet recommendation for reducer
Old Mar 9, 2015 | 03:34 PM
mr.beachcomber
Found this article today about exhaust systems on big cubic inch SBC's. According to the article, they recommend 1 7/8" headers for SBC's with displacements above 420 cu in. Definitely worth a read.
To exhaust
