Vibration
Old Aug 14, 2002 | 06:48 PM
ONETECH's Avatar
ONETECH
Default Vibration
I have a vibration at between 3,000-3,800 rpm. It does not matter what gear I'm in or speed, it is related to rpm. I'm leanning toward a clutch system problem......
Anyone have any ideas?
Old Aug 14, 2002 | 07:24 PM
MoMo's Avatar
MoMo
Default Re: Vibration (ONETECH)
Yes I do. Does your engine vibrate only in gear or also when in neutral at that rpm? If only in gear, look to your drivetrain. If also in neutral, then get a fluidamper and see if that helps. Could be a bit out of balance.
If it points to your driveline, it could be something simple like driveshaft wobble. You could have your driveshaft balance checked at a driveshaft shop. Also check all U-joints to make sure you don't have a wearing one that "clunks" on you. That's a start.
Check that and post back here on the results, and we'll go from there.
Old Aug 14, 2002 | 08:41 PM
ONETECH's Avatar
ONETECH
Default Re: Vibration (MoMo)
Thanks for the information MoMo.
I'll check first thing tomorrow.........
Just off the top of my head.....It seems that it also has some vibs in nuetral...
Old Aug 15, 2002 | 01:59 PM
douglite's Avatar
douglite
6th Gear
I have the same problem with 1980 corvette. previous owner had all the u joints replaced . any suggestions.
Old Aug 19, 2002 | 09:27 AM
norvalwilhelm's Avatar
norvalwilhelm
MoMo He says it vibrates between 3000 and 3800 regardless of what gear he is in. If it is a driveline problem would it still show up say in 1st
at 3-38 then again in 2nd etc. Wouldn't a drive line problem just show up at certain speeds and nothing to do with engine rpm?
Old Aug 25, 2002 | 02:36 PM
ONETECH's Avatar
ONETECH
Well,
:confused: I have narrowed it down to the motor. :confused: Just revving the engine at a stand still causes a vibration. I tried another harmonic balancer, -NO HELP-...... I think I'm going to go at the clutch, pressure plate, throw-out bearing and the heavy dual mass fly wheel. I've been wanting to replace these items anyway. I want to replace the dual mass fly wheel with a single mass. This will save around 23-27 lbs. of rotating mass. My feeling is that the dual mass fly wheel is where my vibs are originating.
To Vibration
