Engine casting number
Old Aug 28, 2002 | 09:49 PM
shotgun_000's Avatar
shotgun_000
Default Engine casting number
I found this number on my block(passenger side): 14088548
Accoding to one source, the year is 86-94.
According to another, it is 86-88
I can't go by the year of my car, mine is a C3 with a C4 engine.
The problem I am having is with buying parts. I've been told that this engine is an 87 model, but 87 seems to be a pivotal year.
The heads look like they are aluminum. The intake looks like the old style intake, used on older 350's (I'm running a Q-Jet).
So, does this engine have a roller cam?
If so, do I buy a roller cam for 87-up? Or 87-earlier?
It seems to me, since the intake is the older style, then I should buy a cam for 87-earlier.
Can someone clarify?
Thanks!
Old Aug 30, 2002 | 03:17 PM
belair55's Avatar
belair55
Default Re: Engine casting number (shotgun_000)
a few years ago I ran across two identical casting blocks. One had a roller and one did not. The non-roller had the lifter tree bolt bosses cast but were not drilled and tapped. I would just pull the intake and see if it has the roller lifter trees.
