cryptonite crank? what is it?
Old Sep 5, 2002 | 09:50 PM
QuickVet's Avatar
QuickVet
Default cryptonite crank? what is it?
someone I know is trying to sell me a stroker kit with a "cryptonite crank" that he says is worth $2500 alone. what the heck is he talking about. ever heard of them. I searched the internet and only found one person that mentions this kind of crank but offers no other details.
stay interested or walk?
Old Sep 5, 2002 | 10:56 PM
Monty's Avatar
Monty
Default Re: cryptonite crank? what is it? (QuickVet)
It's actually spelled "Kryptonite", and it's just a trade name for a series of cranks made by LA Enterprises. Very good quality. LAE is one of the more popular crank manufacturers used by NASCAR Winston Cup teams.
Old Sep 5, 2002 | 11:12 PM
QuickVet's Avatar
QuickVet
Default Re: cryptonite crank? what is it? (Monty)
where can i find more info. Is there a website you know of? This guys does have a modified race car that his son races. He told me that it is from his car with only a few hundred miles on it. I have also heard his name mentioned on the radio a few times when they are naming the winners from that weeks races. any idea what this crank might be worth? im gonna do another search for a website now.
Old Sep 5, 2002 | 11:29 PM
Monty's Avatar
Monty
http://www.crankshaft.com/
Old Sep 5, 2002 | 11:32 PM
redvetracr's Avatar
redvetracr
I believe the "LA" stands for Larry Arnold. Before you walk ask if you get the harmonic balancer and what pistons are in it, most of those sprint car guys are into EXTREME lightweight and use a -12 piston or a 14 or 15 degree piston. Finding heads & an intake (that will fit under any Corvette hood and that you can afford might be a problem. Most of the sprint car guys don`t use a balancer, if this is the case it is now time to turn and run away. ...redvetracr
Old Sep 5, 2002 | 11:54 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: cryptonite crank? what is it? (redvetracr)
Redvetteracer: What is a 15 degree piston?
Old Sep 6, 2002 | 12:00 AM
redvetracr's Avatar
redvetracr
Default Re: cryptonite crank? what is it? (69 N.O.X. RATT)
It has to do with the angle the valve sits in in the head. They make MUCH MORE power than the typical 23 degree valve angle.
...redvetracr
PS: I think there is also a 12degree combination available
Old Sep 6, 2002 | 10:34 AM
J-Rod's Avatar
J-Rod
Kryptonite is the name of the alloy they use. The other name for it is EN30B. It is some really bad stuff. There was a good article on these cranks severla year ago in one of my car mags that went throught the entire forging and machining process.
They do produce some very light Sprint Car cranks, and some stuff for T/F.
Overall, they are some of the best cranks on the market.
Old Sep 6, 2002 | 08:49 PM
QuickVet's Avatar
QuickVet
Default Re: cryptonite crank? what is it? (J-Rod)
i guess im gonna have to ask this guy for more detail. mabey i will get the kit.
To cryptonite crank? what is it?
