Can Someone PLEEZ Run These Heads.......
Old Sep 8, 2002 | 10:48 PM
tnt76vette's Avatar
tnt76vette
Default Can Someone PLEEZ Run These Heads.......
Casting # 14014416? Would they flow better than my 882's if larger valves were installed? Thanx in Advance.......... :cheers: :cheers: :cheers: For those that dont know: these are 58cc heads off of a 305......
[Modified by tnt76vette, 12:35 AM 9/9/2002]
Old Sep 8, 2002 | 10:52 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
Default Re: Can Someone PLEEZ Run These Heads....... (tnt76vette)
i can't help you directly but i did find a site awhile back that helped me track down the 305 heads i just installed. you might have to do a search but the site was "nastyz28" or something like that. the guy hadn't updated it in a while but for stuff as old as ours, it has plenty of information. he lists #s for blocks, heads, cranks and a whole bunch of other old chevrolet iron. good luck, hope you find it.
Old Sep 9, 2002 | 05:27 PM
belair55's Avatar
belair55
These are 80-85 305 HO heads. 58cc, 1.84-1.5 valves, 165/59cc ports
They have a 5cc larger intake port than the 882's 160cc.
Old Sep 10, 2002 | 11:14 AM
IronJen's Avatar
IronJen
Abby Normal
Default Re: Can Someone PLEEZ Run These Heads....... (belair55)
good heads for a 350! ;) :yesnod:
Old Sep 11, 2002 | 12:16 AM
tnt76vette's Avatar
tnt76vette
Default Re: Can Someone PLEEZ Run These Heads....... (clutchdust)
Tried to sell them on the Forum for 250.00........Over 100 lookers but nobody wanted them. Since then I have been following your posts and decided that I will keep them and put them on this winter..... :D
To Can Someone PLEEZ Run These Heads.......
