What are Splayed main caps
Old Sep 9, 2002 | 03:32 PM
95Purple's Avatar
95Purple
Default What are Splayed main caps
Topic said it all. I am about to do a 383 for my 95 and been looking at what needs to be done to the block. I have for bolt mais already what is the splayed thing and do you need it? Sounds like something you have done to a cat or dog so it wont breed. :rolleyes:
Old Sep 9, 2002 | 03:42 PM
scorp508's Avatar
scorp508
Instead of all bolts going straight into the main caps, you'll have 2 that go in at an angle.
Old Sep 9, 2002 | 03:43 PM
Monty's Avatar
Monty
Default Re: What are Splayed main caps (95Purple)
On a splayed cap block, the outer bolts are splayed outwards 18* or 20*, usually just on the #2, #3, and #4 main caps. Most high-performance aftermarket, and high-end Bow-tie blocks feature this. It is possible to convert a 2-bolt main block over, but it's generally not worth it for a 4-bolt(straight).
The benefit is that by splaying the outer bolts, they engage a much stronger area of the bluck, where the main webs meet with the block.
If you've got a good 4-bolt already, you should be fine unless you're building something for very high rpm and/or hp, higher than is typically built for the street.
Old Sep 9, 2002 | 06:54 PM
vader86's Avatar
vader86
like they said, the bolts just go in at an angle, which makes the bottom end tougher for high hp situations
when i do my 383, im goin with splayed mains
Old Sep 9, 2002 | 06:59 PM
Vette9d1's Avatar
Vette9d1
Default Re: What are Splayed main caps (vader86)
At what point is the 2 bolt main not enough? Or are you guys just trying to make these engines indestructable? :D
Old Sep 10, 2002 | 01:08 AM
sinistervette's Avatar
sinistervette
Default Re: What are Splayed main caps (Vette9d1)
At what point is the 2 bolt main not enough? :D
Naturally aspirated, I've yet to find a 2 bolts limitations! I've built many 2 bolts from 302ci. up to 416ci. and have yet to break any of them. I've run several 10.5-1/11.5-1 compression 406's in circle track racing, and had a 355 12.5-1, iron head, solid flat tappet, cast crank,(all because of division rules for stock car) that dyno'd 516hp/485tq. It ran 4 seasons, with new rings and bearings every winter, in a pro stock nova turning 6800-7000 rpm on a 3/8 mile dirt track. Never had a problem. If you think about what the guys like "Grumpy Jenkins" did in the 60's before the 4 bolts, and before large main journal steel cranks, the small block chevy is very tough. It is when you get into forced induction, and spray, that you can really stress test the bottom end! :D :cheers:
Old Sep 10, 2002 | 10:13 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: What are Splayed main caps (sinistervette)
Pic says more than words :
Old Sep 10, 2002 | 10:20 AM
95Purple's Avatar
95Purple
Default Re: What are Splayed main caps (Twinnie)
I understand now. I can see how they would be better then just four straight bolts, where the force could stretch bolt till they yield and break. A side load on the bolts would be harder to break. Thanks for the info.
To What are Splayed main caps
