block question. part #?
Old Sep 19, 2002 | 07:58 PM
QuickVet's Avatar
QuickVet
Default block question. part #?
once you have the part number on a block, how do i find out what it is good for? i heard some truck motors wont work well with some heads so i need to know which will work. where can i check the part number?
Old Sep 19, 2002 | 08:13 PM
scorp508's Avatar
scorp508
http://www.gmpartsdirect.com you should be able to plug it in and see what it is. Otherwise you can go here..
http://www.mortec.com/castnum.htm
Old Sep 19, 2002 | 08:30 PM
QuickVet's Avatar
QuickVet
Default Re: (scorp508)
thanks. i think i have the wrong number. looks like it has to be only numbers :crazy:
Old Sep 19, 2002 | 08:45 PM
scorp508's Avatar
scorp508
What'cha got?
Old Sep 19, 2002 | 10:24 PM
QuickVet's Avatar
QuickVet
V0219TB0 :confused: i was told it is from a pickup truck. but my pops told me you cant use some truck blocks because the good heads wont bolt up to em or something. :confused: so i asked the guy to see if there is a different number on it. Supposed to be a 2 bolt 350 :smash:
Old Sep 19, 2002 | 11:05 PM
No Go's Avatar
No Go
Default Re: (QuickVet)
I thought all normal small block heads bolted to normal small block blocks...when you add LT1/LT4, etc things aren't the same.
Old Sep 19, 2002 | 11:12 PM
QuickVet's Avatar
QuickVet
Default Re: (No Go)
my pops thinks the deck height is different on the truck blocks. true ?
Old Sep 20, 2002 | 09:17 AM
GregP's Avatar
GregP
Some truck big blocks have a taller deck, all small block GM decks are the same.
-Greg
Old Sep 21, 2002 | 07:01 AM
QuickVet's Avatar
QuickVet
Default Re: (GregP)
cool. thanks for clearing that up for me :cheers:
To block question. part #?
