Help.... welding my broken Header ??
Old Sep 24, 2002 | 09:07 PM
Beach Bum's Avatar
Beach Bum
Default Help.... welding my broken Header ??
My smog tube on my 1 3/4" Ceramic coated Super Comp Hooker headers have broken.... which happens to be about 2" away from the exhaust port.
Does anybody know anything about welding ? I have zero experience in this area.
Can they been re-welded, and expect it too live, especially considering they are only a couple of inches out from the exhaust port ?
How about the JB weld goo ? Any chance of that stuff lasting more than an hour ?
Thanks for any help!!! :)
Beach Bum
Old Sep 24, 2002 | 09:08 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Help.... welding my broken Header ?? (Beach Bum)
have somebody tack it with a mig
Old Sep 24, 2002 | 09:09 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
Default Re: Help.... welding my broken Header ?? (CORKVETTE1)
jb wont hold i dont think
Old Sep 24, 2002 | 10:11 PM
sinistervette's Avatar
sinistervette
It can be welded, just make sure when the guy does it that he scrapes the ceramic coating from where the weld will be(if he's good, he'll know this!). Mig is fine, but if you find someone with a tig it would be better. Have him use either a stainless(yes stainless) rod or if he has it "super missle" rod. I'm don't remember the # for the super missle, but if he knows much about welding, he will have it or could get it. This will be stronger than origional as long as the metal is good! JB WILL NOT LAST! Have it welded, you'll be OK! :D :cheers:
Old Sep 25, 2002 | 02:40 AM
Beach Bum's Avatar
Beach Bum
Default Re: Help.... welding my broken Header ?? (sinistervette)
Thanks Cork and Sinister !! :)
I'll look into Tig very soon !!
cheers,
Beach
Old Sep 25, 2002 | 03:35 AM
ol,RJ's Avatar
ol,RJ
the stainless is a good idea.
I'd tig it and use minimum heat, just a little at a time and let it cool. that way you'll save as much of the coating as possible. don't forget to paint it with something after its fixed, while the stainless won't rust, the edge's of the weld are still plain steel and will be unprotected.
Old Sep 25, 2002 | 12:20 PM
Vic'89's Avatar
Vic'89
Beach - How did it break ? Do you think it was fatigue ?
Vic
Old Sep 25, 2002 | 05:13 PM
BLUE ONE's Avatar
BLUE ONE
Default Re: Help.... welding my broken Header ?? (Vic'89)
Make sure you clean all the carbon deposits from the inside of the header pipe ( ideally ) as it can be absorbed into the weld and it makes the weld brittle which over time will cause it to crack again. make sure it fits well before and after welding so as not to put it under stress on assy as this will cause it to crack again
Tig is the prefered option as it will be the neatest and look factory fresh
Mig is just as good for this appilcation but cosmetically it is not as good.
JB will not work !!!!
:cheers:
Old Sep 25, 2002 | 11:00 PM
Beach Bum's Avatar
Beach Bum
Default Re: Help.... welding my broken Header ?? (BLUE ONE)
Thanks for the tips guys... thats good stuff !!! :)
Will be having it welded tomorrow or Friday.
cheers,
Beach
Old Oct 10, 2002 | 01:18 AM
MIKER's Avatar
MIKER
Hey Beach Bum, I have stumbled onto your post a little too late but I had the same problem with my Jet Hot coated (inside and out) Headman headers. They are equipped with the AIR tubes. While being drop KICKED across the USA by UPS, 4 of the 8 welds around the AIR tubes were cracked badly enough to see daylight through them between the outer edges of the factory welds and the tubes.
I had them TIG welded with stainless steel and it worked out very well. We carefully ground off just enough of the Jet Hot coating to make a clean weld. They are now better than new!
Good luck with your repair.
Old Oct 10, 2002 | 01:42 PM
backtrail69's Avatar
backtrail69
St. Jude Contributor
buy burlier headers and not risc messing the ones you have up
To Help.... welding my broken Header ??
