376 LSX Recommendation
Old Mar 12, 2018 | 11:02 AM
patrick4588's Avatar
patrick4588
Default 376 LSX Recommendation
Ive sourced a 376 LSX block and now contemplating rotating assembly. I want the motor to be bulletproof and able to turn 1500hp without worry. . Its a full blown race car, and will be boosted plus nitrous. What is best of best? Molnar, Callies?
Im considering possibly destroking and revving to 8000. If I do a 4.125 bore and 3.625 stroke, ill have a 388ci and an over square motor. 1.14 bore/stroke. pair with some high flowing 6 bolt ls7 heads. I think ill need a solid roller for this correct?
The car only weighs 2000lbs, I do not need big torque down low, it will just cause more tire spin and traction issues. so revving it higher and pushing peak tq up higher seems ideal.
Old Mar 12, 2018 | 11:03 AM
patrick4588
S480 turbo 96mm turbine t6 1.32
Old Mar 12, 2018 | 01:54 PM
patrick4588
Also, looking at dry sump oil systems. open to recommendations
Old Mar 20, 2018 | 01:59 PM
patrick4588
with it being a forced induction setup, should I go bigger intake and exhaust ports? if I go solid roller, is crower my only option for rockers? or are there bolt in solutions that don't require machining?
Old Mar 20, 2018 | 04:17 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
You would likely get more responses in the C5 or C6 forced induction section of the forum.
To 376 LSX Recommendation
