Composite distributor gear
Old Oct 23, 2002 | 04:25 PM
Monty's Avatar
Monty
Default Composite distributor gear
Might be old news, but Comp is now offering a composite distributor gear. for those of us who run billet roller cams requiring the use of a bronze distributor gear, this seems to be a worthwhile option. I just got mine today, so I can't attest to it personally yet, but Comp claims they've seen much better longevity from them over the bronze gears. I was going through a broanze gear about every 5000 miles, they are claiming to have seen over 20,000 miles and still going. It costs a little more, $90, than the bronze gears, 430, but if it lasts that much longer it should be worth it in the long run. I also feel a little better about plastic particles flowing through my engine over bronze particles.
Comp's part number is 12140 if you are interested.
Old Oct 23, 2002 | 07:01 PM
Flareside's Avatar
Flareside
Default Re: Composite distributor gear (Monty)
It's not old news to me. Thanks Monty! Sounds like just the thing I need for the '79 I'm buying next week (it has a solid roller 406 in it). I wasn't looking forward to the bronze gear hassles.
Summit has them in stock for $99.99.
Old Oct 24, 2002 | 02:14 PM
norvalwilhelm's Avatar
norvalwilhelm
I ran bronze gears for years changing it about every 2 years. The last time I emailed Comp Cams with my roller cam part number and they told me I didn't need a bronze gear and that the stock steel gear would work with my roller cam. I ran it last season like this but haven't pulled it yet to check wear.
Old Oct 24, 2002 | 02:43 PM
jackson's Avatar
jackson
Default Re: Composite distributor gear (norvalwilhelm)
Not all roller cams are "billet" ... billet requires special dist gear ... unless cam is made so its gear is pressed-on iron.
Old Oct 24, 2002 | 02:46 PM
Monty's Avatar
Monty
Most roller cams from Comp do not require a bronze distributor gear, as Comp uses a roller cam core featuring a pressed on cast iron cam gear. Unfortunately for me, no cam company that I am aware of offers a cam core with the cast iron gear for BBC sized bearing journal small block cams. They are all billet and have a steel gear.
Old Oct 24, 2002 | 02:47 PM
Monty's Avatar
Monty
Jackson, didn't mean to be redundant. You posted while I was still typing mine. :)
To Composite distributor gear
