LT4 Head Gasket Specifications?
Old Oct 23, 2002 | 06:29 PM
No Go's Avatar
No Go
Default LT4 Head Gasket Specifications?
Planning on doing some cylinder head work on my LT4 and would like to nail down the compression ratio afterward...but need specs on the current OEM LT4 head gasket.
I believe it to be .049 in compressed thickness, but do not know its diameter?
Thanks for the help.
Old Oct 25, 2002 | 09:54 PM
No Go's Avatar
No Go
Default Re: LT4 Head Gasket Specifications? (No Go)
TTT
Old Oct 25, 2002 | 10:12 PM
John W's Avatar
John W
Is the part number that you are intersted in 12557236? If so check the this link. On page 3 of 10,top-right corner, it indicates that the bore is 4.100.
http://www.dallasexportsales.com/DES...et_Catalog.pdf
Hope this helps,
John
Old Oct 26, 2002 | 10:07 AM
No Go's Avatar
No Go
Default Re: LT4 Head Gasket Specifications? (John W)
Thanks.
I'm not sure of the part number, but that shouldn't be too hard to figure out.
To LT4 Head Gasket Specifications?
