DESKTOP 2000 QUESTION
Old Oct 25, 2002 | 10:40 AM
johns73's Avatar
johns73
Default DESKTOP 2000 QUESTION
Hello just ordered dd2000 was wondering if there any tricks to useing? I have been told its fairly accurate. I'am relly curious as to what my setup is for hp and torque. :D
Old Oct 25, 2002 | 01:36 PM
bcwaller's Avatar
bcwaller
C2 of Year Finalist (performance mods) 2019
Default Re: DESKTOP 2000 QUESTION (johns73)
Dyno2000 is "faily accurate". I would really call it "optimistic", but not all that far off. I have simulated stuff like a 327/350 and come within 10-20 on the peak numbers, but I have not seen full curves for the engines I have compared against.
The program is very simple, and there really are no tricks, other than finding Cam and Head flow files. Did you buy it with the Cam files?
There is one resource I found with lots of files you can download:
http://www.aros.net/~rbuck/dyno2000/Welcome.html
Also, Chevy Hi Performance has lots of head flow numbers you can turn into flow files
http://www.chevyhiperformance.com/ed...&viewtype=text
Old Oct 25, 2002 | 02:54 PM
SWCDuke's Avatar
SWCDuke
Default Re: DESKTOP 2000 QUESTION (bcwaller)
I think it's fairly accurate on top end power, but less so on low end torque. It assumes perfect fuel atomization and mixture distribution, but a big cam and carburetor are often far off this mark. so be careful and view the low end numbers, which are very important for a street engine, with a grain of salt.
Also, realize that it basically simulates SAE gross power, except where you select mufflers, but the exhaust restriction is very modest, so "installed power" - essentially SAE net is going to be less when you factor in a real street exhaust system, accessories, fan, and underhood air temp.
Be sure to read the manual and keep in mind the limitations of the program. Cam characterization is critical to accuracy, and I think one of the major limitation is not allowing the used to input actual lift-crank angle data.
Duke
Old Oct 25, 2002 | 03:19 PM
johns73's Avatar
johns73
Default Re: DESKTOP 2000 QUESTION (SWCDuke)
Thanks for your reply. This fourm is a very helpful tool in trying to gather information. I'am hoping the it will be close(dd2000) i don't have alot of experience in modifying small blocks so this looked like a good tool to try as well as reading as much infomation on small blocks on how to get the most out of them. Thanks Again John :cheers:
Old Oct 25, 2002 | 03:29 PM
dtorc4's Avatar
dtorc4
As far as using DD2000 to compare different parts, cams, heads, etc., I think it's a pretty good tool. I have probably plugged in 20 different cams trying to find one I liked. For comparisons, it is great (i.e. Cam "A" has a flatter hp curve than cam "B", but cam "C" has a higher RPM torque peak than Cam "A").
Of course, I'm not going to go around saying I have a 400 hp, 450 ft/lb engine b/c DD2000 says I do. I will wait to have it dynoed before I start bragging.
Old Oct 25, 2002 | 04:09 PM
johns73's Avatar
johns73
Thank you for the links i'am sure the will be helpful. I ordered thru summit and didn't know that there were cam files also avaliable. I ordered and wanted it shipped overnite and recieved a confirmation today saying they sent it ground :mad i wanted it for the weekend. This has happened with me useing summit before guess i'll use jegs next time. Thanks John
Old Oct 25, 2002 | 04:19 PM
bigblock66vette's Avatar
bigblock66vette
I have Desktop Dyno 2000 also and have filled in everything except the heads section. I can not find my heads on there. IS there a flow file some where I can get. I have a Big Block Chevy with a set of Dart Pro-1 heads 2.25/1.88 325cc runners. Any ideas?
Old Oct 25, 2002 | 06:36 PM
bcwaller's Avatar
bcwaller
Default Re: DESKTOP 2000 QUESTION (66 SC'ED VETTE)
Check out the Chevy Hi Performance link. They have:
Dart Pro 1
122cc Chamber, 325 cc Intake Port
lift intake exhaust w/pipe
0.050 40 27 27
0.100 76 58 58
0.200 141 93 95
0.300 200 135 140
0.400 251 170 180
0.500 293 200 215
0.600 325 223 238
0.700 345 237 255
0.800 355 252 273
E/I 79% 85%
To DESKTOP 2000 QUESTION
