fuel injector question
Old Nov 6, 2002 | 07:47 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Default fuel injector question
when i start the car (not the vette....another car i just bought ) the idle is roughf for like 30 seconds & then it feels better....kinda clears out. i think i have a injector that is leaking......any way i can tell? :confused:
Old Nov 6, 2002 | 09:46 PM
J Z06's Avatar
J Z06
scorp had one stuck WIDE OPEN Recently. that's the least of his problems.
what he did to test them, was pull them from the bosses...put a piece of paper under each injector...primed the ignition and viewed each injectors results. obviously, if you have fuel on the paper...you have a leaky injector. see his post on c4 tech/perf or IM him scorpma508 on aol IM.
