Centrifugal supercharging?
Old Nov 11, 2002 | 12:31 AM
71vettman's Avatar
71vettman
Default Centrifugal supercharging?
This isnt somthing I would be able to finance right now but I was just currious to find out if any ones done this before. I would like to supercharge my 454 along with a TPI setup. I know the basics behind centrifugal blowers but not nearly enough. Does anyone know what the advantages would be if I were able to install 2 instead of one? Would I be able to install 2 physically smaller blowers and have the same or more boost as a unit that takes up more space. It would be awsome to have a supercharged engine without it showing through the hood. :yesnod: Any info on centrifugal blowers would be great. Thanks
Kevin
Old Nov 11, 2002 | 09:30 PM
bigblock66vette's Avatar
bigblock66vette
Default Re: Centrifugal supercharging? (71vettman)
If you send me your fax number I can send you some information on a twin procharger setup on a 68 camero. It was installed on a 454 BB. It has an intercooler also. I will try and scan them in for you if you don't have a fax. Let me know.
Will
Old Nov 11, 2002 | 10:44 PM
71vettman's Avatar
71vettman
Default Re: Centrifugal supercharging? (66 SC'ED VETTE)
I dont have a fax but that would be awsome if you could scan them for me....If its not too much trouble :yesnod: That sounds exactly like what I want to do with mine.
If you do get a chance to scan them, my e-mail is stiingray71@lycos.com
thanks..................Kevin
Old Nov 13, 2002 | 02:39 PM
bigblock66vette
I am having problems getting my scanner loaded in. The drivers are giving me problems. I am still working on it. I have the article right here along with several pictures of the twin Paxton set-up on a small block chevy. I will get them to you ASAP.
Sorry for the delay
Will
Old Nov 13, 2002 | 04:02 PM
71vettman's Avatar
71vettman
Default Re: Centrifugal supercharging? (bigblock66vette)
no problem. Thanks for taking the time to try scanning them.
Kevin
To Centrifugal supercharging?
