TrickFlow Heads
Old May 29, 2020 | 04:03 PM
Larphred's Avatar
Larphred
Default TrickFlow Heads
I’m very unhappy with a set of TrickFlow heads I purchases for my SBC. I’ve done everything I could to build a strong bottom end to accept nitrous. I shopped around & settled on TrickFlow bare heads w/Manley valves and Crane springs, etc. when I was almost finished and ready to put on my Crane stud girdle, the holes were off. Evidently one must use proprietary TrickFlow stud girdle which are only sold with their own poly lock nuts.
Ive never seen this before, especially since Summit Racing advertises that the heads are compatible with most SBC aftermarket parts.
I have tried to call them for 5 days, waited on the phone, left messages, etc. so I’m a bit frustrated.
Old Jul 10, 2020 | 09:32 AM
Kevova's Avatar
Kevova
IDK which head you have, however trickflow made a twisted wedge or canted valve head. With the revised valve angles the standard SBC won't work.
Old Jul 10, 2020 | 11:48 AM
Larphred's Avatar
Larphred
Thanks Kenova, but these are standard 23 degree sbc heads. The poly lock rocker arm nuts come so close to fitting my Crane stud girdle, perhaps 0.010” off. In my opinion, they were designed so the user must buy Trick Flow poly locks and stud girdle.
But, then again, I could be wrong.
Old Jul 10, 2020 | 02:20 PM
Kevova's Avatar
Kevova
TF must have changed valve spacing away from stock possibly due how ports were configured.
Old Jul 10, 2020 | 03:40 PM
cv67's Avatar
cv67
St. Jude Donor '05
Never fun to find that out after you bought them.....thats a huge downside with chinese heads noone wants to listen to.
Do you have to have a stud girdle? What cam are you running and size studs?
Old Jul 10, 2020 | 04:06 PM
Larphred's Avatar
Larphred
Trick Flow heads aren’t Chinesium, they are made in USA.
my cam is Crane roller #119841. Intake lift 0.539” at valve. Exhaust lift 0.558” at valve. Redline is 7000 RPM. MANLEY valves & rods, Wiseco pistons
Old Jul 14, 2020 | 10:36 AM
cv67's Avatar
cv67
St. Jude Donor '05
know they are not chinese, was correlaing your problem with them
Where did you buy them? Summit and Jegs have good return policies.
Old Jul 14, 2020 | 11:51 AM
Larphred's Avatar
Larphred
Thanks, good suggestion. I’ve been dealing w/ Summit & Jegs a lot. Their return policies are second to none.
However, I bought the heads bare because I wanted Manley valves and Crane springs. They have been port matched to the intake manifold so I wouldn't think Jegs would take them back.
appreciate your suggestion.
To TrickFlow Heads
