How to Measure Piston Deck Height?
Old Nov 25, 2002 | 07:24 PM
No Go's Avatar
No Go
Default How to Measure Piston Deck Height?
Still trying to finalize my compression ratio on a late model LT4 OEM shortblock.
My final measurement is finding the piston deck height. I assume it is around .020 down in the hole, so to speak.
How can I measure this? Is this as easy as using a straight edge and feeler guage on clean piston and deck and top dead center?
I don't have many tools other than these...certainly no bridge and micrometer...:)
Thanks.
Old Nov 25, 2002 | 07:59 PM
1MoorTym's Avatar
1MoorTym
Default Re: How to Measure Piston Deck Height? (No Go)
I think you've got it.
Old Nov 25, 2002 | 09:53 PM
SWCDuke's Avatar
SWCDuke
A depth mike is nice, but a machinists bar and feeler gages are almost as good. You should rock the piston back and forth until you get the same measurement on both sides. Forged pistons at three to four thou can really make a difference - less with cast pistons at one thou, but rock them anyway until you're sure they're straight.
Duke
Old Nov 27, 2002 | 03:50 PM
No Go's Avatar
No Go
Default Re: How to Measure Piston Deck Height? (SWCDuke)
Thanks folks.
I will give it a shot.
Old Nov 27, 2002 | 05:02 PM
belair55's Avatar
belair55
A magnetic base dial indicater is the easiest and most accurate.
Old Dec 8, 2002 | 05:37 PM
No Go's Avatar
No Go
Default Re: How to Measure Piston Deck Height? (belair55)
Where would the best place to get a 'quality' tool?
Thanks again.
Old Dec 8, 2002 | 06:41 PM
66427-450's Avatar
66427-450
i agree with belair55, it also comes in handy to find TDC.
just borrow one from a local bud
Old Dec 9, 2002 | 10:06 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Thanks again.
I bought one from JC Whitney. I didn't want to spend a fortune for a tool I'd use only a handful of times. I think I paid $50 or so. So far I've used it to check crank shaft end play & rotor runout.
Old Dec 10, 2002 | 08:40 AM
GregP's Avatar
GregP
Thanks again.
http://www.mcmaster.com - I buy LOTS of stuff from them. Usually order by 5pm and have it the next day (from their NJ warehouse).
-Greg
To How to Measure Piston Deck Height?
