Shift Points and Shifting Manually
Old Dec 14, 2020 | 09:44 PM
Hockeypickles23's Avatar
Hockeypickles23
3rd Gear
Default Shift Points and Shifting Manually
So is it okay to manually shift an auto valve body 700r4? It's a built trans up to around 600hp (we'll see about that) and has TV cable adjusted properly. Governor is shifting trans at around 4k from 1-2 and 2-3. 5k from 3-4. Don't want to change governor right now, so planning on manual shifting at 5500, if it's safe. Really only using for going "fast" and not when just cruising around.
Old Jan 24, 2021 | 02:28 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Nothing wrong with manually shifting an automatic.
