Stethoscope sounds
Old May 19, 2021 | 05:51 AM
Garra671's Avatar
Garra671
Default Stethoscope sounds
Hey. I’m posting this in this forum because im
hoping you guys will be a bit more niche towards very fine listening and tuning.
anyways. My question is, If any of you guys have used a stethoscope or like device to listen to engine internals?
im curious what a healthy engine bearing should sound like?
Is it just a smooth running metal sound? Almost like a roller skate?
or should it be literally soundless. Even with the stethoscope right there listening to it spin?
Old Jun 12, 2021 | 11:37 PM
Kevova's Avatar
Kevova
Engine bearing related to crankshaft and camshaft should be silent. The journals ride on a cushion of oil. Things like.oil and water pumps will hum. Valvetrain will have a uniform tapping or rattle.
Knocking, hammering type tap, growling, grinding.or whine fall under concerns
Listening to engines or components where there is no known concerns can give you a basis of what's normal.
Old Jun 12, 2021 | 11:38 PM
Kevova's Avatar
Kevova
To Stethoscope sounds
