How critical is rod bolt torque?
Old Dec 23, 2002 | 09:02 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default How critical is rod bolt torque?
I read on another forum about a guy who over torqued his 3/8 rod bolts to 60-65! Rec 50ftlb. Are the rod bolts trash now?
When I do mine should I buy a new torque wrench to assure accuracy? My wrench is about 20yrs old!
Len
Old Dec 23, 2002 | 09:34 AM
Monty's Avatar
Monty
Default Re: How critical is rod bolt torque? (1970 Stingray)
Arguably the most critical fastener in an engine. Rob bolts can lead to potentially catastrophic engine failure if they are significantly either over- or under-torqued. Overtorquing can stretch the fastener beyond it's point of elasticity and cannot return back to it's original dimension. Undertorquing will not provide enough preload(stretch) on the fastener.
I'd recommend using a rod bolt stretch gauge if you have one. Using a torque wrench allows you to approximate the amount of bolt stretch, but this will allow you to directly measure it. The appropriate range is provided with the rod bolts, usually .0004" - .0006".
According to ARP, the suggested torque is 20% below it's maximum, which means those rod bolts you are referring to are trashed. As for your torque wrench, your machine shop can probably help you out in either testing or correcting it's calibration. If it was taken care of - never used to remove a fastener, always returned to '0' when not in use, and not abused, there's no reason it might not still be accurate. Only a calibration can test for sure though.
Old Dec 24, 2002 | 01:05 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
Default Re: How critical is rod bolt torque? (Monty)
Thanks Monty. Now I'll know to pay careful attention when I do mine.
I'll be using a beam type torque wrench that I've had for about 20 years. Should I get a new one or can this one be calibrated? I don't think I've ever dropped it and take pretty good care of my tools.
Len
Old Dec 24, 2002 | 10:03 AM
Monty's Avatar
Monty
A beam torque wrench is better than nothing, but a quality "click" type torque wrench is more accurate when properly used. I don't know if the beam type can be calibrated, other than insuring the pointer is at "0" before torque is applied.
If you're not going to be building engines very often, I'd just rent or borrow a "click" type wrench. The beam type is good enough for most other fasteners on a car - a few lbs of torque variation usually aren't as critical.
Old Dec 25, 2002 | 07:47 PM
66427-450's Avatar
66427-450
I agree with Monty 100%..... rods, and their bolting, are critical (most stressed area of the engine)....... If you plan on taking it over 6000 I'd get the best ARP's (Pro series, only a few $ more) and torque them per the instructions (you don't torque them as tight as weaker bolts)...... also have your rods reconditioned by someone into hi-performance, and I'd recommend a little polishing, it's easy/cheap. Whatever you do, don't go to a hacker, many rods end up weaker than before they were worked.
[Modified by 66427-450, 7:40 AM 12/27/2002]
Old Dec 27, 2002 | 12:39 PM
wallyknoch's Avatar
wallyknoch
Default Re: How critical is rod bolt torque? (66427-450)
Put new bolts in if any question comes up with the old bolts. Less expense now than trashing a good engine later.. :thumbs:
Old Dec 28, 2002 | 09:02 PM
VetteLS6's Avatar
VetteLS6
ls6 rods torque to 63 lbs no more than 70lbs....If you use the GM boron Bolts just do them to .009" stretch...(maybe 74lbs). I was under the impression that the idea was preload the rod to attain good bearing crush. shed some light here. :)
Old Dec 29, 2002 | 08:04 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
Default Re: How critical is rod bolt torque? (wallyknoch)
Thanks for the info guys. I'lll be using ARP bolts, they're brand new and I just read their recommendations. Torque the bolt to 50ftlb, then loosen, repeat x 3.
Old Dec 29, 2002 | 01:27 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
always use a rod bolt stretch gauge because torque reading depend on the lube,feel and surface finish. you can then just use a box end wrench to do the rod bolts. :chevy
Old Dec 29, 2002 | 02:15 PM
66427-450's Avatar
66427-450
Default Re: How critical is rod bolt torque? (clem zahrobsky)
I agree, it's all about preload really, but if you use the lube that comes with the ARP bolts, and torque them as they instruct, everything should be cool.
:seeya
[Modified by 66427-450, 2:29 PM 12/29/2002]
To How critical is rod bolt torque?
