Piston related- Anybody have access to an old TRW parts list?
This request goes back to my prior post asking for info on BB oval port heads. Due to the holidays I haven't been able to reach the folks that might have the info I need. I'm trying to figure out what pistons I have so I can get a clue on dome configuration & valve clearance w/ various cams.
When I did my engine back in 1990 I used forged aluminum TRW pistons- part #L2300F. Since Federal Mogul bought out at least part of TRW it looks like their parts numbers have changed & I can't find anyplace that has info on my pistons. Can anybody either find this old part # or find a cross reference for the new one so I can get the specs? Thanks in advance. :cheers:
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Re: Piston related- Anybody have access to an old TRW parts list? (Les)
L-2300F .140 dome height,16.8 cc dome volume, weight 777 grams,5/64" x5/64" x 3/16" ring grooves, .0015 piston to wall clearance :chevy
Les,
Part # L2300F specs.
4.25" Bore
1.767" Comp. Dist.
777 Grams Weight
16.8 cc Dome Volume
.140" Dome
Compression Ratio with 100.9 cc heads 9.86, with 119.0 cc heads 8.48
This is still a good part number.
John.
4.25" Bore
1.767" Comp. Dist.
777 Grams Weight
16.8 cc Dome Volume
.140" Dome
John.
Re: Piston related- Anybody have access to an old TRW parts list? (69bblock3x2)
Damn, you guys are good!!!! Many thanks! I'll print that out & see what cam/head options look good when I can catch up to the head guru I go to. :cheers:
