427-454 block compared to 502 block?
The good news is the aftermarket has adapted to these new generation blocks and new heads, 2-piece rear main adapters, etc. allow more interchangeability than was originally available.
And both Dart and Merlin offer excellent aftermarket versions of the Mark IV Bow Tie block.
Take care,
Mark
[Modified by VetteLS6, 12:28 AM 1/3/2003]
Bill, how's the 502 coming? My 540 project has been at a standstill all year (lack of $$ :(), but I hope to get back to it this winter if the '79 sells.
BUt I dont think it can happen that many times anyway. By the way do BIg BLocks have a more of a chance to emit more toxins than Small Blocks? Say for same compression for both, both fuel injected, and both have a 140CID difference-350 vs 540? :flag
A standard bore 502 block isn't 4.5", it's 4.47", so you have one extra overbore there. The aftermarket blocks are usually 4.5" stock.
Remember, if you buy a 4.5" block, and want to go bigger, you will have to pay for another bore job instead of just the hone, and your throwing away boring opportunities. Some people think the extra ~10 cubes are that important, other don't, it's up to you.
If I were buying a used engine, and it was at maximum bore, it wouldn't be nearly as desirable.
[Modified by Flareside, 4:01 PM 1/3/2003]
If it does blow or I get a clyinder wall scratch I'll replace the engine block with a 502 block or a merlin.
By the way does the Merlin outweigh the 502 block or are they the same outter specs, then same cane be said for outter specs on a 427/454 block and a merling block?
Also, I've read that the 502's do tend to run a bit hot.
