How do you pick a stall speed?
Old Jan 3, 2003 | 08:50 AM
GregP's Avatar
GregP
Default How do you pick a stall speed?
For new car, never run so no prior baselines. How to make a first guess.
Wt ~ 2800#
Since the car has never run before and there is no reference for a baseline, how do I get a good first guess?
Wt ~ 2800# (actually hoping for lower but don't know what I'll be able to get to)
Gear = 4.86:1
Tires = 29.5 x 15.50
HP ~ 550 @ 6000
TQ ~ 560 @ 4500
Thanks - Greg
Old Jan 3, 2003 | 02:11 PM
VetteLS6's Avatar
VetteLS6
Default Re: How do you pick a stall speed? (GregP)
Get some dyno time and choose from there. :blueangel:
Old Jan 3, 2003 | 03:28 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: How do you pick a stall speed? (VetteLS6)
:iagree:
Everything I have always heard is you want your TC stall ~500 RPM less than max torque. :cheers:
Old Jan 3, 2003 | 09:49 PM
Russ Bellinis's Avatar
Russ Bellinis
Are you building a prupose built drag racer or is it going to be a street/strip car? If it is built for drag racing only, 500 rpm below peak torque is probably fine. I think you would lose a lot of driveability on the street with it set up like that, though. You need to have a high enough stall speed so that your engine is making enough torque to get moving when the tc stalls. I think that is where you need to get a dynbo base line, so you know not only peak torque, but what does your torque curve look like?
Old Jan 3, 2003 | 11:45 PM
VetteLS6's Avatar
VetteLS6
Default Re: How do you pick a stall speed? (Russ Bellinis)
hey hey hey ....get to the dyno :lurk:
Old Jan 4, 2003 | 07:14 AM
DeenHylton's Avatar
DeenHylton
If this is going to be a drag-only car and it WILL only weigh 2800 lbs. it will go faster with a 2-spd. Powerglide...probably 90% of the 9.90 cars in NHRA run a glide. With a 4.88 gear your engine should be built to turn at least 7,600 RPM (and up). You'd also want to lose the locker and go with a spool if it's strip only. A strip converter for your setup will be from 4000-4500 stall. If you plan on seeing street duty it gets mighty uncomfortable much over 3200-3500 stall. Deen
Old Jan 6, 2003 | 08:16 AM
GregP's Avatar
GregP
Default Re: How do you pick a stall speed? (DeenHylton)
It's really a street car that will be raced maybe once or twice a year, which is why the 200-4R trans. From all the inputs I've received here and elsewhere it looks like around 1 3500 stall 9" lock-up converter will be the nominal choice.
Thanks - Greg
Old Jan 6, 2003 | 10:54 AM
Ganey's Avatar
Ganey
Greg
Besides the TQ curve, another thing to consider on the street is traction, even w/ slicks, time for a burnout, etc..
:cool:
To How do you pick a stall speed?
