Not another smog delete thread
Old Sep 24, 2022 | 01:13 PM
Shunyun's Avatar
Shunyun
Default Not another smog delete thread
What's the current state of the art for smog design in a "street legal" "resto-mod"?
Let me clarify. Must I achieve California smog standards with 35 year old smog design or are there better ways? Can I pass smog test at the exhaust tip with a crate motor without including all the ancient smog systems? If I do a simple rebuild, are there any improvements I can make along the way? What do I have to keep, what can I upgrade? Are there ways to make the improvements and get around visual inspection?
My point is that I don't want to cripple my smog systems; I want to modernize and improve them.
So maybe an alternative way to ask is to say "How can I modernize smog so my '88 corvette is street legal and performs better than my '22 [brand excluded to avoid silly rabbit holes...]?"
BTW, I'm considering rebuild vs crate but I haven't a clue what to do about this smog issue
Old Sep 24, 2022 | 01:48 PM
cv67's Avatar
cv67
St. Jude Donor '05
It all has to be there in the stock location.
Id leave it be...maybe take the pump, accessories off, polish them, brackets etc.
my 67 is supposed to have a smog pump on it. No they dont ck but if they wanted to they could give me a real issue
CHP is a stickler for stuff like that. Modern cats work much better than the old pellet type. Make sure they have the Ca EO # stamped on them they check.
Old Dec 26, 2022 | 01:51 PM
drive it's Avatar
drive it
Only way is to drop in a late model LS with all the original smog equipment that came on the LS. Then take it to a Kali smog referee to get it certified.
Old Feb 9, 2023 | 08:44 PM
Tech141's Avatar
Tech141
First problem is - You live in Kalifornia.....
Old Mar 7, 2023 | 12:52 AM
mjsusa1's Avatar
mjsusa1
you could pass smog/inspection with a new crate engine that is CARB certified and includes modern computer and CATS (search E-ROD LS3 ) FYI if you weren't aware of that, but its pricey
To Not another smog delete thread
