Help with cam identification
Old Nov 9, 2022 | 09:01 PM
Livewild's Avatar
Livewild
Default Help with cam identification
Thanks for any help in advance
These are the numbers I see on the cam(BBC). The first set are on the shaft after the first lobe.
139606 031053
and the other set are where they normally are
4218B/4279B
R110 0
V1511-11
Old Nov 9, 2022 | 09:10 PM
Vette5311's Avatar
Vette5311
Don’t know about the numbers but the lobes look like a roller.
Old Nov 9, 2022 | 09:23 PM
Livewild's Avatar
Livewild
here are some pictures I took compared to a flat tap cam I had. I was told it was a solid lifter cam. But I was also lied to about a few other things. He had a gear drive that said went with it which I also have
Old Nov 9, 2022 | 10:05 PM
Vette5311's Avatar
Vette5311
Yes the last picture is a good comparison. The others look like a flat tappet with lobes going flat.
Old Nov 15, 2022 | 07:44 PM
BrandonU's Avatar
BrandonU
That is a solid roller cam. The core will be 8620. The copper coating protects the core between the lobes during the heat treating process.
Brandon Unklesbay
All-In Performance, LLC
Old Nov 15, 2022 | 08:35 PM
Livewild's Avatar
Livewild
Brandon Unklesbay
Thanks for the help! If there is any more information you can give me based off the pictures or numbers I’d appreciate it!
Old Nov 15, 2022 | 08:48 PM
BrandonU's Avatar
BrandonU
I'm sorry but I really can't. I would assume, based off custom cams I've seen, the 42xxx/42xxx are lobe profiles, and the "R110" is the LSA (110). I would also assume the cam is asymmetrical, meaning the exhaust lobe and intake lobe are different. My suggestion is to take to a local speed shop or builder and have it "Cam Doctored". This is where the cam specifics are measured. Typically this is only a very small fee.
Brandon Unklesbay
Old Nov 17, 2022 | 08:08 PM
BrandonU's Avatar
BrandonU
Looking in an old Comp Cams lobe book, they list the 4278 and 4279 lobe profiles in the "RZ" design. I would say this is what you have.
.266/.272 @ .050 on a 110 (.400/.380 lobe lift) The "B" indicates it is for a 1.948 journal (BBC), the "-11" indicates billet steel.
Again, "Cam Doctor-ing" it will tell you the exact numbers. Those were ground for .842 lifters.
Brandon Unklesbay
Old Nov 20, 2022 | 10:08 AM
Livewild's Avatar
Livewild
Brandon Unklesbay
hey I wanted to say thank you for the information and knowledge you passed on. I appreciate the help. I’m planning on looking around my area for a local speed shop to see if they would be able to look over it( cam docto-ring). Thanks again!
To Help with cam identification
