Name that cam!!?
Old Jan 27, 2003 | 06:02 PM
Lionsden's Avatar
Lionsden
Default Name that cam!!?
I was digging through the garage and came across this cam.
It is a pre '86 small block solid roller cam. Can't find the spec card nor do I remember what brand it is. I thought it was an ISKY grind.
Anyone recognize these numbers? Looks like 295DR8 and C9150. Not sure about the symbol. Could it be C on top of a C? Comp Cams?
Old Jan 27, 2003 | 10:39 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Name that cam!!? (Dan Plett)
the 295 is the advertised duration and the cc looks like comp cam
Old Jan 28, 2003 | 01:43 PM
Lionsden's Avatar
Lionsden
Mystry Solved
Here are the specs on tis particular camshaft. The duration @ .050 is
262 on the intake and 272 on thie exhaust. It has a .585 lift on the intake
and a .550 lift on the exhaust. It is ground on a 108 lobe seperation. Let me
know if there is anything else that I can help you with.
Thanks,
Brock @ Comp Cams
To Name that cam!!?
