Is this normal? (Pushrods/Guideplates/Rockers)
Old Feb 11, 2003 | 09:15 PM
Ken73's Avatar
Ken73
Cruise-In III Veteran
Default Is this normal? (Pushrods/Guideplates/Rockers)
See the linked video I made: (caution, it's a little over 2 megs!)
Rocker Movement
These are L98 Corvette late-model D-port heads that I purchased from a forum member a few years ago that I've finally gotten around to putting on my motor; those are the stock guideplates which have roughly 3/8" openings, and I have 5/16" pushrods on the way that are .100" longer (used a length checker to find that I needed longer pushrods.) The rockers are just stamped steel roller-tip 1.6:1 rockers..
As you can see, there's about 1/16" clearance between the guideplate and pushrod (this is just a stock pushrod that I used for testing purposes.)
Is this normal, or do I need guideplates with less tolerance so they don't move side-to-side so much? It seems like they'd rattle around in the guideplate but I'm not sure. :confused:
[Modified by Ken73, 8:16 PM 2/11/2003]
Old Feb 11, 2003 | 10:36 PM
danno85's Avatar
danno85
Default Re: Is this normal? (Ken73)
That's too much clearance. You need to get a set of guide plates
for 5/16" pushrods. :thumbs:
Dan
Old Feb 11, 2003 | 11:07 PM
Ken73's Avatar
Ken73
Default Re: Is this normal? (danno85)
Yup. I confirmed it in the "Chevrolet Power" book I have. Here's the quote:
The pushrod guideplates installed on H.O. cylinder heads are for self-aligning production rocker arms. These rail type rocker arms have guides that center the rocker tip on the valve stem; consequently the pushrod guideplates are not hardened. If you install any other type of rocker arm (including old-style production rockers without aligning guides,) hardened pushrod guideplates should be substituted
So, I guess I'll be getting a new set of guide plates! :rolleyes:
Old Feb 12, 2003 | 12:04 AM
danno85's Avatar
danno85
That's interesting becaue I didn't know that any heads for self-aligning
rocker arms even had guide plates. That explains the wide gap though
because you don't want "two" alignment mechanisms. The guide plates
in this case must just be to hold the pushrods "close by" while the rocker
arms are off.
Dan
Old Feb 12, 2003 | 09:44 AM
gkull's Avatar
gkull
What kind of media player do i have to download to see your movie. I run across that type from time time.
Old Feb 12, 2003 | 09:47 PM
CFI-EFI's Avatar
CFI-EFI
Besides being for 3/8ths inch push rods, those guide plates are for the "Bowtie" aluminum heads. Those heads have the exhaust valve guides .050 offset, further from the intake guides, than any production head. I haven't contacted Chevy, yet, but I need a set. The yahoo that built my engine made the same mistake, in reverse. Would you want to get rid of those? Good luck, and...
RACE ON!!!
Old Feb 13, 2003 | 08:37 AM
Ken73's Avatar
Ken73
Default Re: Is this normal? (CFI-EFI)
RACE ON!!!
Actually, they're 1990 Corvette heads, so the guide plates are *not* hardened. The original rockers (which I still have) were self-aligning. They have a dimple in the middle where the valve stem sits, and since the guide plates aren't really "necessary" they got away with using 5/16" pushrods that weren't hardened, either.
If you want these guide plates, you're welcome to them - give me $5 + the cost of shipping (to make it worth my while.) I bought new Comp Cams ones last night for $17 at the local race shop......
Old Feb 13, 2003 | 08:38 AM
Ken73's Avatar
Ken73
Default Re: Is this normal? (gkull)
Apple Quicktime.. it's the format my camera makes, unfortunately.
Old Feb 13, 2003 | 09:14 PM
CFI-EFI's Avatar
CFI-EFI
DEAL!
Your "Cheverolet Power" book must be later than mine. Mine is dated 1988. I have never heard of "hardened" or not, guide plates. Only that hardened push rods must be used with guide plates. And that non guide plate engines have non hardened push rods. My book makes the distinction between normal and Bowtie guide plates by the identifying "05" stamped into them. I will e-mail you tomorrow with my address and make arrangements to pay you. Thanks, and...
RACE ON!!!
Old Feb 14, 2003 | 04:55 AM
Twin_Turbo's Avatar
Twin_Turbo
The 05 marking means these guideplates are hardened ones
Marck
Old Feb 14, 2003 | 04:24 PM
bill mcdonald's Avatar
bill mcdonald
arms are off.
Dan
The deal with those 90 heads, the guide plates are not "real" guide plates. They were put there by the factory to make engine assembly easier. the self aligning rockers do all the work, after the enigne is together, the guide plates are pretty much useless.
Old Feb 16, 2003 | 01:44 AM
h rocks's Avatar
h rocks
How did you determine that you needed .100" longer pushin' rods?
Old Feb 16, 2003 | 03:57 AM
Ken73's Avatar
Ken73
Default Re: Is this normal? (h rocks)
Pushrod length checkers. Set the rocker on and get the roller tip set on the valve stem so it wipes across the entire face properly. I've got 1.6:1 stamped-steel roller tips.
Old Feb 16, 2003 | 05:36 PM
69stingray's Avatar
69stingray
You can download the "free" version from here:
http://www.apple.com/quicktime/download/
Old Feb 16, 2003 | 09:51 PM
h rocks's Avatar
h rocks
Did you use a spring for checking hydraulic valve lifter rockers? The reason I ask is that I thought I needed them too once upon a time. Got BAD info from guys that only had solid lifter experience while checking them with the heads on the motor.
To Is this normal? (Pushrods/Guideplates/Rockers)
