Compression Ratio estimate help
Old Feb 16, 2003 | 01:29 PM
Chucks76's Avatar
Chucks76
Default Compression Ratio estimate help
I am building a new motor and here are the stats:
.040 over 350 motor
Flat top pistons with the small 4 valve relief
vortec heads with 64 cc compression chamber
Head gaskets have compression of 9cc
Can someone help out with what my compression ratio will be?
Old Feb 16, 2003 | 03:10 PM
American Boy's Avatar
American Boy
Default Re: Compression Ratio estimate help (Chucks76)
It's would be around 9.6:1. It's an estimate since I don't know if your block is decked, I used 0,025" below deck. And I presumed that the piston have 6 cc with the four notchs.
Stephan
Old Feb 18, 2003 | 11:01 PM
lspalding's Avatar
lspalding
This will help you out
http://www.kb-silvolite.com/calc.phtml
To Compression Ratio estimate help
