SR intake, Porting or Extrude hone?
Old Feb 18, 2003 | 05:50 AM
Danbien's Avatar
Danbien
2nd Gear
Default SR intake, Porting or Extrude hone?
What is the best way to get maximum airflow through a Super ram intake manifold having it ported or getting it Extrude honed or a combination of both?
Old Feb 18, 2003 | 09:52 AM
Caboboy's Avatar
Caboboy
Default Re: SR intake, Porting or Extrude hone? (Danbien)
Hand port and blend then extrude hone if you need the absolute max out of it. I've read about SRs flowing as much as 280 CFMs, but have never actually talked to anybody that has one and flowed it himself to determine those kind of numbers. I just went thru this, here's the thread: http://forums.corvetteforum.com/zerothread?id=493089
Good luck to you! :cheers:
Old Feb 18, 2003 | 01:38 PM
HeaderDesign.com's Avatar
HeaderDesign.com
Default Re: SR intake, Porting or Extrude hone? (Caboboy)
I just wanted to make a comment regarding the intake/head flow test with the throttle body installed. If you flow the entire setup, the pressure drop should be referenced near the runner entry inside the plenum (static). That way the losses through the throttle body won't be subtracted from the runner/port/valve flow rating when you do your engine analysis. The cylinder draws air from the runner, and then air and pressure from the entire manifold.
The flow through the air filter/snorkle/MAF/throttle body should be evaluated separately. Your engine analysis uses this flow rating to calculate average pressure in the plenum.
So your intake flow values are a little better than you think.
Old Feb 18, 2003 | 10:32 PM
Caboboy's Avatar
Caboboy
Default Re: SR intake, Porting or Extrude hone? (HeaderDesign.com)
Thanks for the good news, and thanks for the in depth info on IM! :cheers:
Old Feb 19, 2003 | 09:03 AM
Danbien's Avatar
Danbien
2nd Gear
Thanks guys, That's the info I needed. Another question, I know that the RPM range of a manifold largely related to runner length but did anyone gain RPM by porting or extrude honing the manifold. Can the SR intake be used effectively to 6500 rpm?
Old Feb 19, 2003 | 07:39 PM
Caboboy's Avatar
Caboboy
You'll get something out of it, but not anything approaching 6500. Off the top of my head, I'd guess 6000 tops if the rest of your setup is complimentary. Is this an existing motor and parts, or a new plan? If you want RPMs, you'd be better off with a miniram.........
Be careful matching your heads and cam to whatever intake you settle in on too, good luck!
To SR intake, Porting or Extrude hone?
